7 Replies Latest reply on Jul 20, 2009 8:45 AM by wwscoper
    placing xml menu items inside a movie clip
    wwscoper Level 1
      Hi all,
      I have a basic XML menu that dynamically attaches the menuItem instances to the stage. They are being attached to the root timeline, but I want to put all of the actionscript inside a movieclip called "menu1_mc". I am having some trouble with the proper syntax, because when I move the code inside of the movieclip, I can't get them to attach to the stage unless I still reference _root. I'd like them to attach at (0,0) of the menu1_mc movieclip.
      myXML.onLoad = function(){
      var linkname:Array = this.firstChild.childNodes;
      //Set a for loop
      for(i=0;i<linkname.length;i++){
      //Push the button name into the names Array
      names.push(linkname[i].attributes.NAME);
      //Push the button link into the links Array
      links.push(linkname[i].attributes.LINK);
      //Attach the button Movie Clip from the libray give it an instance name and place it on the next highest level
      _root.attachMovie("button","btn"+i,_root.getNextHighestDepth());
      //Set the y position of the buttons
      _root["btn"+(i)]._y = yPosition;
      //Increace the varible yPosition 15 pixel each time the loop runs to place each button under each other
      yPosition = yPosition + 25
      //Place the button name from names Array into the blackTxt text box
      _root["btn"+(i)].buttonText.Txt.text = (names[i]);
      //Assign the btnRelease function to the button onRelease state.
      _root["btn"+(i)].onRelease = btnRelease;
      Thanks!
        • 1. Re: placing xml menu items inside a movie clip
          if you want to attach items to the current timeline, use "this" instead of "_root".
          • 2. Re: placing xml menu items inside a movie clip
            wwscoper Level 1
            I tried that first. Updating the script to this doesn't work.
            //Set varible to store the XML childNodes
            //This allows you to get the number of buttons in the XML file.
            //You'll use this tell flash how many times to loop the for loop.
            //Set a for loop
            this.attachMovie("button","btn"+i,this.getNextHighestDepth());
            this["btn"+(i)]._y = yPosition;
            this["btn"+(i)].buttonText.Txt.text = (names[i]);
            this["btn"+(i)].onRelease = btnRelease;
            • 3. Re: placing xml menu items inside a movie clip
              what doesn't work?
              • 4. Re: placing xml menu items inside a movie clip
                wwscoper Level 1
                Hey. I appreciate the replies. I changed "_root" to "this" in my code but the movieclips are no longer dynamically being attached to the stage.
                • 5. Re: placing xml menu items inside a movie clip
                  use:
                  var tl:MovieClip=this;
                  //Set a for loop
                  tl.attachMovie("button","btn"+i,tl.getNextHighestDepth());
                  tl["btn"+(i)]._y = yPosition;
                  tl["btn"+(i)].buttonText.Txt.text = (names[i]);
                  tl["btn"+(i)].onRelease = btnRelease;
                  Thanks!
                  • 6. Re: placing xml menu items inside a movie clip
                    wwscoper Level 1
                    Thanks! This worked.
                    • 7. Re: placing xml menu items inside a movie clip
                      you're welcome.
