0 Replies Latest reply on Jul 14, 2009 11:57 AM by Paul Reilly
    [svn:fx-trunk] 8553: * Fixed -dump-config, -keep-generated-signatures, and -link-report, so
    Paul Reilly Level 1
      Revision: 8553
      Author:   preilly@adobe.com
      Date:     2009-07-14 11:57:06 -0700 (Tue, 14 Jul 2009)
      Log Message:
      • Fixed -dump-config, -keep-generated-signatures, and -link-report, so
        they write to the output directory when Flash Builder sets
        DEFAULT_OUTPUT_DIRECTORY_TOKEN.  Previously they were writing to the
        target file's parent directory.
      tests Passed: checkintests
      Needs QA: YES
      Needs DOC: YES, uses should look for generated files and directories
                 in the bin folder instead of the src folder.
      Bug fixes: SDK-21158
      API Change: NO
      Reviewer: Pete F.
      Cycloner: Gaurav
      Code-level description of changes:
        tools/CommandLineConfiguration.java
        tools/CompcConfiguration.java
          Modified validate() to no longer process dumpConfigFile and create
          the generated directory when -keep is true.  It's done by the
          super class.
          Removed getDumpConfig(), cfgDumpConfig(), getDumpConfigInfo(), and
          getOutput(), because they have been moved to the super class.
        tools/oem/internal/LinkerConfiguration.java
          Added getOutput() and getTargetFile() stubs.
        tools/oem/internal/ApplicationCompilerConfiguration.java
          Modified validate() to no longer create the generated directory
          when -keep is true.  It's done by the super class.
          Removed getVirtualFile(), because it's no longer used.
          Added getOutput().
        tools/ASDocConfiguration.java
          Added getTargetFile() stub.
        tools/ToolsConfiguration.java
          Added getOutput(), abstract getTargetFile(),
          createOutputDirectory(), validateDumpConfig(),
          validateKeepGeneratedSignatures(),
          validateKeepGeneratedActionScript(), getDumpConfig(),
          cfgDumpConfig(), and getDumpConfigInfo().
          Modified validate() to call alidateDumpConfig(),
          validateKeepGeneratedSignatures(), and
          validateKeepGeneratedActionScript().
        tools/flexbuilder/BuilderApplication.java
        tools/flexbuilder/BuilderLibrary.java
          Removed -dump-config from the excludes list.
        compiler/common/CompilerConfiguration.java
          Modified setSignatureDirectory() to just set the
          signatureDirectory.
          Modified cfgSignatureDirectory() to check the
          DEFAULT_OUTPUT_DIRECTORY_TOKEN first, then default to the "."
          directory.
        compiler/common/Configuration.java
          Modified getOutputPath() to check DEFAULT_OUTPUT_DIRECTORY_TOKEN
          first.
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-21158
      Modified Paths:
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/common/CompilerConfiguration.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/common/Configuration.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/ASDocConfiguration.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/CommandLineConfiguration.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/CompcConfiguration.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/ToolsConfiguration.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/flexbuilder/BuilderApplication.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/flexbuilder/BuilderLibrary.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/oem/internal/ApplicationCompilerConf iguration.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/oem/internal/LinkerConfiguration.jav a
