1 Reply Latest reply on Jul 15, 2009 7:33 AM by flashharry!
    copy & paste in textarea, shows correct but one long string, no returns?
    flashharry! Level 1
      I have a text area, I copy from an email a list of names, or I copy from a text file a list of names.
      They display in the text area correctly, i.e. they look like they have newlines.
      but if I split them they appear to be just one line of text
      var searchText:Array = new Array();
      searchText = textSearchBox.text.split(/\r|\n/);
      trace(ObjectUtil.toString(searchText));
      results
      (Array)#0
        [0] "00013.TIF00008.TIF00021.TIF844.mov00013.TIF00008.TIF00021.TIF844.mov00013.TIF00008.TIF00 021.TIF844.mov"
      if I edit the text and backspace/add return, it looks the same in the gui, but the results are what I want.
      results
      (Array)#0
        [0] "00013.TIF"
        [1] "00008.TIF"
        [2] "00021.TIF"
        [3] "844.mov"
        [4] "00013.TIF"
        [5] "00008.TIF"
        [6] "00021.TIF"
        [7] "844.mov"
        [8] "00013.TIF"
        [9] "00008.TIF"
        [10] "00021.TIF"
        [11] "844.mov"
      Question, what do I need to split on from a copy & paste without needing to edit list
      TIA
      Dean
        • 1. Re: copy & paste in textarea, shows correct but one long string, no returns?
          flashharry! Level 1
          found a thread with the same issue..
          http://forums.adobe.com/thread/424273
          this pointed to a fix
          http://bugs.adobe.com/jira/browse/FP-780
          basically this only affects flashplayer 10 on the Mac.
          in the script block of your code add this
          private function cleanCRLF(event:TextEvent): void {
               event.preventDefault();
               var textField:TextArea = event.target as TextArea;
               var currentText:String = textField.text;
               var insertionPrefix:String = currentText.substr(0, textField.selectionBeginIndex);
              var insertionSuffix:String = currentText.substr(textField.selectionEndIndex, currentText.length);
              textField.text = insertionPrefix + event.text + insertionSuffix;
              var caretIndex:int = insertionPrefix.length + event.text.length;
              textField.setSelection(caretIndex, caretIndex);
          add the function call to you text area's textInput event
          <TextArea width="600" height="300" id="textSearchBox" text="" textInput="cleanCRLF(event)"/>
          flash
