1 Reply Latest reply on Sep 10, 2008 5:29 AM by riesvantwisk
    Which is better frame works use along with flex
    srinilE
      I am developing an hospital application, mainly includes the management of outpatients and in front end i am using flex but in back end i did not get a clear idea about which frame work has to use or need of a new architecture. i just need some suggestion which of these spring,EJB 3.0 and Jboss Seam is better for back end implementation.
      Thanks and Regards
      kumar
        • 1. Re: Which is better frame works use along with flex
          riesvantwisk
          Hey kumar ,
          I don't have experience with a lot of frameworks but I am using Blaze-DS + Spring with deployed under glassfish.
          I think you biggest problem here is how to make the frontend pluggable, extensible and easy to maintain.
          I do make all single screens as single modules. and each module have it's own java class to do the work + some java classes for general perpose.
          Teh whole thing is build in ANTS and using jnit as a testing framework for java. I don't have anything yet to do automated UI testing.
          Ries
