1 Reply Latest reply: Aug 30, 2009 9:21 PM by my robo RSS
    Context-Sensitive Help Issues
    octechwriter Community Member
      I have problem where context-sensitive help markers disappear from my .h files.
      I started with a .h file from my old WebWorks project. After a little reformatting, I was able to get the CSH Map IDs to load and map properly to my RH topics (I had to do the mapping manually even though the topic names were the same) . I was also able to add several new Map IDs to facilitate help in the latest version of our product. The final help was tested and worked properly.
      Now that it's time to update the help for another new release of our product, I am noticing that many, many of the Map IDs that were in my project before have now disappeared. Anybody have any idea what is happening here?
      I'm sick of struggling to get RH to play nice with these .h files. Manually remapping the Map IDs to the topics each time we release a new project is terribly dull work and time consuming.
      Is there any way to add the Map ID numbers to the CSH markers in FM so that RH can automatically map the IDs to the topics? I want to use the Map IDs we already have established with our development team; I don't want RH's automapping which starts at one and advances incrementally through all of your topics).
        • 1. Re: Context-Sensitive Help Issues
          my robo
          I think you dint check the option "Project Map File" from drop down list in the dialog box for editing Map ids.  For this, in the main menu point to "Edit" tab, select "Map Id's". Edit Map Ids dialog box appears. Choose the option for Map File as "Project Map File" from the drop down list.
