4 Replies Latest reply on Sep 22, 2008 3:00 PM by Gregory Lafrance
    Width property won't bind to a value
    istrasci Level 1
      OK, I have some (seemingly) simple data binding that's giving me warnings when I compile... I have a custom component and an HBox... I simply want the HBox's width to be whatever the width of the component is...
      <mx:HBox width="{comp.width}" ... > ... </mx:HBox>
      <my:component id="comp" .../>
      I do not declare a width for the component in the instantiation, nor in the declaration... Flex determines it by the width of all its sub-components... Anyway, when I compile, it's saying, "Data binding will not be able to detect assignments to 'width'." Am I missing something simple here...? Is it just because of the order I insert them (component after HBox)...? I don't think that should affect it... Someone help me out please!
      - Ian
        • 1. Re: Width property won't bind to a value
          Level 7
          "istrasci" <webforumsuser@macromedia.com> wrote in message
          news:gb8nf8$lr6$1@forums.macromedia.com...
          > when
          > the
          > sub-components...
          > detect
          > just
          > think
          What is component extending?
          • 2. Re: Width property won't bind to a value
            istrasci Level 1
            quote:
            It extends HBox... Should that matter, though?
            • 3. Re: Width property won't bind to a value
              Level 7
              news:gb8s2d$rch$1@forums.macromedia.com...
              Just making sure it wasn't something weird where the width wouldn't be
              accessible. Maybe you'll have to go the roundabout route...setting a
              handler on creationComplete of comp and setting a variable based on that,
              which you'd then bind to from your HBox.
              Also look at constraints and percentages.
              HTH;
              Amy
              • 4. Re: Width property won't bind to a value
                Gregory Lafrance Level 6
                This works, so I don't know why you are having a problem:
