0 Replies Latest reply on Jul 15, 2009 6:53 AM by Cal Wilson
    See Also Control
    Cal Wilson
      I apologize up front if this is considered a duplicate post, but I do not use the forum often enough to know how to reopen a topic.
      The original post and more information are here:
      http://forums.adobe.com/thread/444392?tstart=0
      I am using RH8.
      The output is Web Help.
      The popup menu related to the See Also controls appears at the top of the topics.
      I want the popup menu to appear next to the button? Is there a way to make this happen?
      The popup menu is positioned correctly in HTML help.
      I recognize that a Topics Found dialog box could be used; however, the dialog box is not visually appealing, etc., etc.
      The post below indicated it might be possible to edit the ehlpdhtm.txt (.js) file to fix the problem. However, since I work primarily with the WYSIWYG, I need help understanding exactly what should be changed in the file.
      http://forums.adobe.com/thread/433051
      Thank you in advance for any assistance, and my apology again.
