In Word there's a setting where you can have a paragraph style or a single paragraph on its own be set to "stay with the next", so that if a page break occurs between the two paragraphs, it will stay with that paragraph and move to the next page. Is there an equivalent way to do this inside of the HTML WYSIWYG editor in RH for printed output of a project? Thanks in advance.
I'm using the latest RH7.
You cannot set it up in RH but what you can do is set up the Word template you select in the last page of the wizard so that the styles have the required attributes. You then map to the styles which you have previously set up in the template.
Thanks. That's what I suspected.
