0 Replies Latest reply on Jul 15, 2009 3:30 PM by Jason Szeto
    [svn:fx-trunk] 8605: Transform bug fixes
    Jason Szeto Level 3
      Revision: 8605
      Author:   jszeto@adobe.com
      Date:     2009-07-15 15:30:29 -0700 (Wed, 15 Jul 2009)
      Log Message:
      Transform bug fixes
      http://bugs.adobe.com/jira/browse/SDK-22046 - Can't set matrix3D property on Transform
      Player declares matrix3D setter with * return type. So mx.geom.Transform override must also use *. Note that once the Player is updated with void, this will need to be changed to void.
      http://bugs.adobe.com/jira/browse/SDK-22146 - AlphaMultiplier and AlphaOffset in color transformation are ignored in MXML Graphics
      Changed the behavior of alpha and ColorTransform for GraphicElement to match the behavior of DisplayObject.
      - ColorTransform.alphaMultiplier and alpha are equivalent and are kept in sync.
      - ColorTransform.alphaOffset is still applied even if alpha is set.
      Implementation details:
      - mx.geom.Transform sets the colorTransformExplicitlySet flag whenever the colorTransform setter is called
      - GraphicElement alpha setter clears the colorTransformExplicitlySet flag whenever it is called
      - Setting GraphicElement.transform will update the alpha property with ColorTransform.alphaMultiplier if a colorTransform was explicitly set
      - Setting the colorTransform on a mx.geom.Transform that is assigned to a GraphicElement, calls setColorTransform, which updates the alpha property with ColorTransform.alphaMultiplier.
      - In commitProperties, the displayObject.alpha is updated only if there is no transform or if colorTransformExplicitlySet is false.
      QE Notes: Need tests for combo of alpha and colorTransform alpha props
      Doc Notes: None
      Bugs: SDK-22046, SDK-22146
      Reviewer: Chet
      Ticket Links:
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/framework/src/mx/geom/Transform.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/primitives/supportClasses/GraphicEleme nt.as
