3 Replies Latest reply on Sep 20, 2008 9:23 AM by Newsgroup_User
    XMLList to XMLListCollection?
    |>AoA<|_killa Level 1
      I'm trying to convert an XMLList to an XMLListCollection because i need to remove some elements from it. But the xmllist doesnt get copied to the xmllistcollection object.
      It doesnt get shown in the Alert box.
        • 1. Re: XMLList to XMLListCollection?
          Level 7
          "|>AoA<| killa" <webforumsuser@macromedia.com> wrote in message
          news:gb2m6a$cal$1@forums.macromedia.com...
          > var xml:XMLListCollection =
          > XMLListCollection(choicesArrayColl[formulaIndexArray[currentTargetIndex]]);
          > Alert.show(xml.toString());
          > for(var o:int = 0; o < xml.length; o++)
          > if(!formulaHandler.getBoolean(xml[o].value +
          > filledInFormulas .toString())){
          > xml.removeItemAt(o);
          > this[formulaIndexArray[currentTargetIndex]].dataProvider = xml;
          I'm not sure why you need to use an XMLListCollection just to remove items,
          but you probably need to take a step back and do something like
          trace(choicesArrayCol.toXMLString())
          trace(choicesArrayCol[formulaIndexArray].toXMLString())
          and so on, and verify that the argument you're passing to XMLListCollection
          contains what you think it does. Also, you may want to try using the new
          operator
          var xml:XMLListCollection = new
          HTH;
          Amy
          • 2. XMLList to XMLListCollection?
            |>AoA<|_killa Level 1
            The "new" operator worked :)
            But now when i remove an element, it also removes it for the original XMLList. I need the original one to have the default content.
            I didn't put it up as bindable or anything like that.
            EDIT: fixed it by doing var xml:XMLListCollection = new XMLListCollection(choicesArrayColl[formulaIndexArray[currentTargetIndex]].choice .copy());
            Now everything works like it should.
            Thanks alot for your help :)
            The reason why i use XMLListCollection is because it has removeItemAt while XMLList doesnt. Got an idea to remove an element another way?
            • 3. Re: XMLList to XMLListCollection?
              Level 7
              news:gb3542$t6p$1@forums.macromedia.com...
              > XMLList.
              You'll need to copy all the nodes you want to keep. An XMLListCollection
              contains a _reference_ to the XMLList, so any changes you make to the
              XMLListCollection actually change the XMLList inside it.
              HTH;
              Amy
