2 Replies Latest reply on Jul 16, 2009 8:06 AM by msakrejda
    mxmlc / compc: automatically link in all source files?
    msakrejda Level 4
      In the standard configuration, compc and mxmlc only link in classes actually used by your project. We're using code generation to get ActionScript classes from our Java classes for AMF serialization. We deal with most of these generically, so we don't automatically reference all the generated classes. Consequently, some of these are compiled out of the final .swf, causing hard-to-track-down serialization issues. Is there a simple way to tell mxmlc / compc to include *all* classes defined in a certain path? I tried to use include-sources, but when I just add all the source files to include-sources (I'm using mxmlc / compc through ant with a fileset for this purpose, for what it's worth, but the problem is not ant-specific), I get weird errors about circular inheritance. Any other strategies for achieving this?
        • 1. Re: mxmlc / compc: automatically link in all source files?
          TeotiGraphix Level 3
          One way you might ba able to acomplish this is when you are auto-generating your actionscript classes from Java, create a classes.as file.
          package
          internal class LinkClasses
              import mx.package.LinkClass;
          Include this class in the compc include class.
          This should alow the linker to pick up all classes very neatly.
          Mike
          • 2. Re: mxmlc / compc: automatically link in all source files?
            msakrejda Level 4
            Thanks; I'd considered something like that, but I'd prefer an
            mxmlc-based solution. It doesn't seem that far-fetched to want to do
            something like this. I can understand this on-demand static linking
            for libraries (e.g., I only want to compile the bits of the Flex
            framework that I actually use into my .swf), but I can't think of a
            good use case for having source in my project that I would want to
            omit just because it doesn't look like it's being used.
