5 Replies Latest reply on Jul 16, 2009 11:18 AM by _Natasha_
    Multiple dataproviders for charts
    ross a
      Hi guys, i can get the basics of multiple data providers working for my charts (i can have two seperate lines on my column chart from 2 seperate sources)
      However my problem is with setting both axis, i have no problem setting the y-axis to teh players score and the x-axis based on the number of inputs (each object in my array collectuion gets a new data point). BUT when i attempt to set the x-axis to be based onvalues solely from the array collection i can no longer display both graphs.
      I am currently using the bellow code snippet to display both lines:
      <mx:series>
                <mx:Array id="StatisticsArray">
                       <mx:LineSeries yField="total_score" id="SummaryLine"
                          form="curve" lineStroke="{s1}" dataProvider = "{StatsShown}">
                         <mx:itemRenderer>
                          <mx:Component>
                           <mx:DiamondItemRenderer/>
                          </mx:Component>
                         </mx:itemRenderer>
                      </mx:LineSeries>
                      <mx:LineSeries yField="total_score" id="ExtraSummaryLine"
                           form="curve" lineStroke="{s2}" dataProvider = "{ExtraStatsShown}">
                       <mx:itemRenderer>
                        <mx:Component>
                        </mx:Component>
                       </mx:itemRenderer>
                    </mx:LineSeries>
                </mx:Array>
      </mx:series>
      So if a set the xField value of each to game_end_at (a date value) it no longer shows both line series
        • 1. Re: Multiple dataproviders for charts
          _Natasha_ Level 4
          yes, it's possible for your question.
          What is the code for horizontalAxis?
          • 2. Re: Multiple dataproviders for charts
            ross a Level 1
            I can not set the code for my horizontal axis except from:
            <mx:horizontalAxis>
                  <mx:LinearAxis padding=".5" id="HAxis" />
            </mx:horizontalAxis>
                <!-- horizontal axis renderer -->
            <mx:horizontalAxisRenderers>
                 <mx:AxisRenderer axis="{HAxis}" showLabels="false"/>
            </mx:horizontalAxisRenderers>
            As i can't set a data provider (because i need 2 different providers) or set the category field I can not base the x-axis on any particular value.. any help is appreciated. :-)
            • 3. Re: Multiple dataproviders for charts
              _Natasha_ Level 4
              It's not correct to use LinearAxis for date values.
              Try CategoryAxis.
              • 4. Re: Multiple dataproviders for charts
                ross a Level 1
                Thanks but i have tried category axis before, the problem arises when i attempt to give my line series an xField :
                <mx:horizontalAxis>
                <mx:CategoryAxis id="HAxis" />
                <mx:series>
                <mx:LineSeries yField="total_score" xField="game_end_at" id="SummaryLine" displayName="{MainGame}"
                form="
                <mx:itemRenderer>
                <mx:Component>
                </mx:Component>
                </mx:itemRenderer>
                </mx:LineSeries>
                <mx:LineSeries yField="total_score" xField="game_end_at" id="ExtraSummaryLine" displayName="{ExtraGame}"
                form="
                <mx:itemRenderer>
                <mx:Component>
                </mx:Component>
                </mx:itemRenderer>
                </mx:LineSeries>
                </mx:Array>
                </mx:series>
                This displays nothing due to the addition of the xField value, the 2 dataproviders have this value but the data does not exactly match as they are date/time values. I need my x-axis to be based on the time values from each data provider (the y-axis can handle two dataproviders total_score values but teh x-axis can not do teh same with end_game_at)
                Thanks again
                • 5. Re: Multiple dataproviders for charts
                  _Natasha_ Level 4
                  I use personal dataProvider per series in my project and there is no problem. But it's a Numbers on X Axis.
                  You should understand that if you use LinearAxis for your chart Number is expected for x-axis values. But Date is not a Number and you don't get what you want.
                  The best way is to write an DateAxis to work with Dates.
