6 Replies Latest reply on Jul 17, 2009 5:46 AM by Gus187
    An internal build error has occurred
    Zolotoj Level 3
      Ok, now it's my turn to get it.
      I have no empty switch statements, or other 'built-in' triggers.
      What to do?
        • 1. Re: An internal build error has occurred
          Zolotoj Level 3
          Just wanna say nothing drives developers out better than this one.
          • 2. Re: An internal build error has occurred
            injpix Level 3
            -Do a project clean.
            -Delete the project's generated directory, if it's there.
            -Make sure all dependent directories are online.
            -Restart Flex or your computer.
            A little more information may help.  Is this error from an Ant build?  Have you done anything listed above?  Is this error presistent?
            • 3. Re: An internal build error has occurred
              Zolotoj Level 3
              <Do a project clean.
              1000 times
              <Delete the project's generated directory, if it's there
              which one? bin-debug?
              <Make sure all dependent directories are online.
              have none
              <Restart Flex or your computer.
              1000 times
              < Is this error presistent?
              110%
              It is simply unbelievable.
              • 4. Re: An internal build error has occurred
                Zolotoj Level 3
                Here is the reason:
                !ENTRY com.adobe.flexbuilder.project 4 43 2009-07-16 10:29:04.652
                !MESSAGE Uncaught exception in compiler
                !STACK 0
                java.lang.NumberFormatException: For input string: "10 0"
                at sun.misc.FloatingDecimal.readJavaFormatString(Unknown Source)
                at java.lang.Double.valueOf(Unknown Source)
                at flex2.compiler.mxml.builder.AbstractBuilder$TextValueParser.percentage(AbstractBuilder.ja va:234)
                at flex2.compiler.mxml.lang.TextParser.parseValue(TextParser.java:382)
                at flex2.compiler.mxml.lang.TextParser.parse(TextParser.java:215)
                at flex2.compiler.mxml.builder.AbstractBuilder$TextValueParser.parseValue(AbstractBuilder.ja va:101)
                at flex2.compiler.mxml.builder.AbstractBuilder.processPropertyText(AbstractBuilder.java:366)
                at flex2.compiler.mxml.builder.ComponentBuilder$ComponentAttributeHandler.property(Component Builder.java:230)
                at flex2.compiler.mxml.lang.DeclarationHandler.invoke(DeclarationHandler.java:94)
                at flex2.compiler.mxml.lang.DeclarationHandler.invoke(DeclarationHandler.java:132)
                at flex2.compiler.mxml.builder.ComponentBuilder$ComponentAttributeHandler.invoke(ComponentBu ilder.java:288)
                at flex2.compiler.mxml.lang.AttributeHandler.invoke(AttributeHandler.java:54)
                at flex2.compiler.mxml.builder.ComponentBuilder.processAttributes(ComponentBuilder.java:157)
                at flex2.compiler.mxml.builder.DocumentBuilder.analyze(DocumentBuilder.java:174)
                at flex2.compiler.mxml.dom.Node.analyze(Node.java:47)
                at flex2.compiler.mxml.ImplementationCompiler.parse1(ImplementationCompiler.java:180)
                at flex2.compiler.mxml.MxmlCompiler.parse1(MxmlCompiler.java:169)
                at flex2.compiler.CompilerAPI.parse1(CompilerAPI.java:2775)
                at flex2.compiler.CompilerAPI.parse1(CompilerAPI.java:2728)
                at flex2.compiler.CompilerAPI.batch2(CompilerAPI.java:443)
                at flex2.compiler.CompilerAPI.batch(CompilerAPI.java:1271)
                at flex2.compiler.CompilerAPI.compile(CompilerAPI.java:1475)
                at flex2.tools.oem.Application.compile(Application.java:1135)
                at flex2.tools.oem.Application.recompile(Application.java:1080)
                at flex2.tools.oem.Application.compile(Application.java:776)
                at flex2.tools.flexbuilder.BuilderApplication.compile(BuilderApplication.java:354)
                at com.adobe.flexbuilder.multisdk.compiler.internal.ASApplicationBuilder$MyBuilder.mybuild(A SApplicationBuilder.java:272)
                at com.adobe.flexbuilder.multisdk.compiler.internal.ASApplicationBuilder.build(ASApplication Builder.java:123)
                at com.adobe.flexbuilder.multisdk.compiler.internal.ASBuilder.build(ASBuilder.java:157)
                at com.adobe.flexbuilder.multisdk.compiler.internal.ASItemBuilder.build(ASItemBuilder.java:7 4)
                at com.adobe.flexbuilder.project.compiler.internal.FlexProjectBuilder.buildItem(FlexProjectB uilder.java:424)
                at com.adobe.flexbuilder.project.compiler.internal.FlexProjectBuilder.build(FlexProjectBuild er.java:264)
                at com.adobe.flexbuilder.project.compiler.internal.FlexIncrementalBuilder.build(FlexIncremen talBuilder.java:131)
                at org.eclipse.core.internal.events.BuildManager$2.run(BuildManager.java:633)
                at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
                at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:170)
                at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:201)
                at org.eclipse.core.internal.events.BuildManager$1.run(BuildManager.java:253)
                at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:256)
                at org.eclipse.core.internal.events.BuildManager.basicBuildLoop(BuildManager.java:309)
                at org.eclipse.core.internal.events.BuildManager.build(BuildManager.java:341)
                at org.eclipse.core.internal.events.AutoBuildJob.doBuild(AutoBuildJob.java:140)
                at org.eclipse.core.internal.events.AutoBuildJob.run(AutoBuildJob.java:238)
                at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
                • 5. Re: An internal build error has occurred
                  injpix Level 3
                  Hmmm...I did a quick search online and found this link:
                  “Internal Build Error” or “Classes Must Not Be Nested” error
                  I am not sure what else to suggest.  Perhaps reinstall FB.
                  • 6. Re: An internal build error has occurred
                    Gus187 Level 1
                    I could suggest commenting your code.... start by doing it to the most of it and see if the error dissapears, if so, continue with a smaller portion of the code until you isolate the part that causes the error, its probably something silly that makes the compiler go crazy..
                    Hope this helps
                    Gus
