2 Replies Latest reply on Jul 16, 2009 11:55 AM by Ether-x
    No compiler Arguments ??
      It would be great to manually implement Compiler Argument, In case of debug configurations for compiler directive such as:
      CONFIG::local {
           // code to compile in this case
      CONFIG::remote {
      the following lines are added to arguments
      -define=CONFIG::local,false -define=CONFIG::remote,true
      I didn't see this option in the new flash builder, I think this is very usefull and should be taken in consideration for developpers.
      Thank you
      (I Hope i'm in the right place)
        • 1. Re: No compiler Arguments ??
          Peter deHaan Level 4
          Add the "-define=CONFIG::local,false -define=CONFIG::remote,true" compiler arguments to the Flex compiler section in the Project Properties dialog.
          1. Right-click project and select Properties.
          2. Click the "Flex Compiler" link in the left menu.
          3. Add "-define=CONFIG::local,false -define=CONFIG::remote,true" in the Additional compiler arguments section.
          4. Click "OK".
          • 2. Re: No compiler Arguments ??
            Ether-x Level 1
            Hi again !
            and thank you for your quick answer, I didn't saw this option, maybe not searching at the right place !!
