0 Replies Latest reply on Jul 16, 2009 11:43 AM by deepa subramaniam (adobe)
    [svn:fx-trunk] 8628: Followup checkin to collapsing the path segments into Path: The data getter used to have to accommodate the case where the data property wasn 't set but the segments property was.
    deepa subramaniam (adobe) Level 2
      Revision: 8628
      Author:   dsubrama@adobe.com
      Date:     2009-07-16 11:43:06 -0700 (Thu, 16 Jul 2009)
      Log Message:
      Followup checkin to collapsing the path segments into Path: The data getter used to have to accommodate the case where the data property wasn't set but the segments property was. In that case, the data getter had to reconstruct the data value by parsing the segments to create the data string. Now we don't have to do that since the segments property is unsettable. _data is always just null (default) or whatever the current data value is.
      QE notes: Regress
      Doc notes: None
      Bugs: None
      Reviewer: Glenn
      Tests run: Checkintests
      Is noteworthy for integration: No
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/spark/src/spark/primitives/Path.as
