3 Replies Latest reply on Jul 20, 2011 3:58 PM by ZACStudios
    Why does a solid black square print out on the document?
    ZACStudios
      Why do some Adobe .pdf files that I get from an architect print a solid black square on the document when printing to a Xerox 510 Wide Format printer.  The document shows up correctly in Adobe reader, but when you print it some areas print as a solid black square.  Attached is a file that is doing exactly this.  If you print it as an 11x17 on a copier, it prints fine.  I played around with drivers for the Xerox printer and was able to fix some files like this, but not all of them and the new driver ended up causing other problems.  Any help is appreciated.
