0 Replies Latest reply on Jul 16, 2009 5:20 PM by Jason Szeto
    [svn:fx-trunk] 8654: TrackBase mouse handling
    Jason Szeto Level 3
      Revision: 8654
      Author:   jszeto@adobe.com
      Date:     2009-07-16 17:20:24 -0700 (Thu, 16 Jul 2009)
      Log Message:
      http://bugs.adobe.com/jira/browse/SDK-22044 - SkinnableComponent mouse handling needs to be MarshallPlan compliant
      I have updated the track based components mouse handlers to be Marshall Plan compliant. The previous code was using the SkinnableComponent.addSystemHandlers which listen for the event on both the systemManager and the stage. I removed addSystemHandler/removeSystemHandler and added the listeners to the sandbox. I also added listeners for the SandboxMouseEvents for MOUSE_UP_SOMEWHERE.
      QE notes: Need marshall plan tests for Slider and ScrollBar
      Doc notes: None
      Bugs: SDK-22044
      Reviewer: Glenn, Alex
      Tests run: ScrollBar, Scroller, Slider
      Is noteworthy for integration: No
      Ticket Links:
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/supportClasses/ScrollBar.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/supportClasses/SkinnableCom ponent.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/supportClasses/Slider.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/supportClasses/TrackBase.as
