5 Replies Latest reply on Jul 17, 2009 10:03 AM by Stan Jones
    Multicamera Workflow
      I have about 70 minutes of ballet recoding shot from two cameras.
      There are 15 individual dances during that 70 minutes, the order of dances does not have to be preserved.
      Currently I am using only two sequences. One is multicam source sequence, another is multicam edit sequence.
      I can see several possiblities of editing this video.
      1. To have only 2 sequences (as described above). Drawback is that with 30-40 switchbacks per dance, the sequence becomes hard to navigate. Also, it is easier to accidentally mess up already finished dances while editing another one.
      2. To have one sequence per dance where all of the multicam editing is done, and later, to assemble the final sequence out of preedited individual dances
      What approach would you recommend?
        • 1. Re: Multicamera Workflow
          Jim_Simon Level 8
          I'd use three.
          Original for the individual clips.  What I call a Cutting Board sequence that I use to make the multicamera cuts.  And from there I Cut/Paste the cut segments into a Final sequence.  This makes it a bit easier to work as any segments already finished are removed from the cutting board.
          • 2. Re: Multicamera Workflow
            Colin Brougham Level 6
            I'd use three, as Jim suggested, but with a slightly different approach. Instead of copy/pasting edited segments from the multicam edit sequence, I nest the multicam edit into a new, final sequence. That way, if I need to make changes, I just jump to the edit sequence and they ripple down to the final sequence. You could also drop sequence markers in the edit sequence demarcating the break between "scenes". These will appear as clip markers in the nested sequence, making it easy to snip it into pieces if you want to rearrange it, add titles or transitions, or just purge the dead space.
            ADDENDUM: Here's a post I wrote about dealing with an issue with multicam sequences. It offers a little workflow advice, though, which is probably more pertinent to this discussion.
            • 3. Re: Multicamera Workflow
              Jim_Simon Level 8
              I used to work that way, myself.  But I found the delay as Premiere works to 'catch up'  in the nested sequence too frustrating to live with.
              • 4. Re: Multicamera Workflow
                By that point, I'm not doing too much heavy-duty editing. It's usually my last step before final assembly. All color-correction and the like is done in the original edited sequence. It does bog the system down a bit, but once I went to Vista 64 and more RAM, it was much less of an issue. Diff'rent strokes for diff'rent folks...
                • 5. Re: Multicamera Workflow
                  Stan Jones Adobe Community Professional & MVP
                  I look ahead to the DVD construction and create a multicam sequence pair for each dance. Use a playlist to create the larger play elements on your DVD.  You can use chapter playlists to create individual dance options, but I find separate movies for each dance easier.  Just as with any approach to offering "scene" selections on DVD, you need to think about where there will be a "jump" (DVD spec issues/search on disk) between scenes.
                  I am still SD and use scenalyzer for capture.  I add a marker on the clip for the beginning and end of each sement, and for everything tha has been continuous, I'll sync it in one sequence, and add markers to make it easy to pull the part for each scene into its own multicam source sequence.
