9 Replies Latest reply on Aug 16, 2010 1:00 PM by jmaing
    Catalyst- Receiving JVM Terminated message on launch.
    WestR
      Just installed application. Can't get it to start up.
        • 1. Re: Catalyst- Receiving JVM Terminated message on launch.
          acath Level 4
          Here are some things to try:
          1) Check out this post: http://forums.adobe.com/message/2054413#2054413
          2) Run the CS4 clean script: http://www.adobe.com/support/contact/cs4clean.html
          3) If those don't work, send along the following information:
          •   Screenshot of the JVM error
          •   OS and OS version
          •   OS locale (if you don't know what this means, your locale is US English =))
          •   Other CS apps you have installed
          Hope we can clear this up,
          Adam
          • 2. Re: Catalyst- Receiving JVM Terminated message on launch.
            Mykola Golubyev Level 1
            Hello,
            I have the same problem.
            Solutions you provided don't work.
            I have Mac Os X 10.5.8. Flash Catalyst CS5 (the only product from CS5). Adobe Media Player. Adobe Flash Player 10.
            LANG = en_US.UTF-8
            • 3. Re: Catalyst- Receiving JVM Terminated message on launch.
              Peter Flynn (Adobe) Adobe Employee
              Hi Mykola,
              Sorry about the problem you're having.
              Here's another thing you can try: go to Applications > Utilities > Java Preferences.  In the "Java Applications" checklist at the bottom, make sure at least one 32-bit option is checked off that is version 5 or higher (if in doubt, send us a screenshot).
              If that still doesn't work, you may be able to get us more diagnostic information by doing this:
              1. Open Terminal
              2. Type "cd /Applications/Adobe\ Flash\ Catalyst\ CS5" and press enter
              3. Type "./Adobe\ Flash\ Catalyst\ CS5.app/Contents/MacOS/Adobe\ Flash\ Catalyst\ CS5" and press enter (be sure to include the "." at the beginning)
              4. Copy any text that is displayed when you do this
              - Peter
              • 4. Re: Catalyst- Receiving JVM Terminated message on launch.
                "Java Preferences" on Mac has 32 bit Java 5 and it is turned on. Java 6 option is turned on either.
                So unless I turn it on I get
                /Applications/Adobe Flash Catalyst CS5$ ./Adobe\ Flash\ Catalyst\ CS5.app/Contents/MacOS/Adobe\ Flash\ Catalyst\ CS5
                _NSJVMLoadLibrary: NSAddLibrary failed for /System/Library/Frameworks/JavaVM.framework/Versions/1.6.0/Libraries/libclient.dylib
                JavaVM FATAL: Failed to load the jvm library.
                So I turned Java 6 option and have managed to launch Flash Catalyst with the following warning message.
                JavaVM: requested Java version (1.6.0) not available. Using Java at /System/Library/Frameworks/JavaVM.framework/Versions/1.5.0/Home
                instead.
                It is ok as temporary solution and I hope you will fix this Guys. And thanks for the Hint.
                • 5. Re: Catalyst- Receiving JVM Terminated message on launch.
                  Hi Mykola,
                  I had a little trouble understanding your reply.  Do you think you could help us out by posting the following?
                  • Screenshot of what the Java Preferences window looks like when Catalyst will not launch (when you get the message "Failed to load the jvm library").
                  • Screenshot of what the Java Preferences window looks like when Catalyst will launch (when you get the message "requested Java version (1.6.0) not available").
                  Thanks!
                  - Peter
                  • 6. Re: Catalyst- Receiving JVM Terminated message on launch.
                    I am sorry I sounded confusing.
                    And here is Java Preferences screen when Catalyst does not launch.
                    Here is Java Preferences screen when Catalyst does launch.
                    • 7. Re: Catalyst- Receiving JVM Terminated message on launch.
                      Hi Mykola,
                      Thanks for the info.  This is interesting -- the settings in the top screenshot work fine on my 10.5 computer.  Can you check one more thing for us?
                      • Open Terminal
                      • Type cd /System/Library/Frameworks/JavaVM.framework/Versions
                      • Type ls -l
                        (note: that's a lowercase L, not number one)
                      • Type Current/Commands/java -version
                      • Type 1.5.0/Commands/java -version
                      • Type file Current/Commands/java
                      • Type file 1.5.0/Commands/java
                      • Copy and paste all the output from these commands and send it to us here
                      Thanks again!
                      - Peter
                      • 8. Re: Catalyst- Receiving JVM Terminated message on launch.
                        Peter, here are the results
                        /System/Library/Frameworks/JavaVM.framework/Versions$ Current/Commands/java -version
                        java version "1.6.0_17"
                        Java(TM) SE Runtime Environment (build 1.6.0_17-b04-248-9M3125)
                        Java HotSpot(TM) 64-Bit Server VM (build 14.3-b01-101, mixed mode)
                        /System/Library/Frameworks/JavaVM.framework/Versions$ 1.5.0/Commands/java -version
                        java version "1.5.0_22"
                        Java(TM) 2 Runtime Environment, Standard Edition (build 1.5.0_22-b03-333-9M3125)
                        Java HotSpot(TM) Client VM (build 1.5.0_22-147, mixed mode, sharing)
                        /System/Library/Frameworks/JavaVM.framework/Versions$  file Current/Commands/java
                        Current/Commands/java: Mach-O universal binary with 3 architectures
                        Current/Commands/java (for architecture ppc7400): Mach-O executable ppc
                        Current/Commands/java (for architecture i386): Mach-O executable i386
                        Current/Commands/java (for architecture x86_64): Mach-O 64-bit executable x86_64
                        /System/Library/Frameworks/JavaVM.framework/Versions$ file 1.5.0/Commands/java
                        1.5.0/Commands/java: Mach-O universal binary with 3 architectures
                        1.5.0/Commands/java (for architecture ppc7400): Mach-O executable ppc
                        1.5.0/Commands/java (for architecture i386): Mach-O executable i386
                        1.5.0/Commands/java (for architecture x86_64): Mach-O 64-bit executable x86_64
                        Honestly I don't remember how and when I changed the Current Java to be 6. Several months ago I moved from JEE 5 to JEE 6 (GlassFish v.3).
                        • 9. Re: Catalyst- Receiving JVM Terminated message on launch.
                          jmaing
                          Hi Peter,
                          I'm having the same problem except I'm running Windows XP SP3. I tried following the previous thread, but the Mac was too different I couldn't navigate to the equivalent areas in Windows. Can you help me?
                          Thank you,
                          Jamie
