8 Replies Latest reply on Jul 28, 2009 5:50 AM by vpxav
    ModuleLoader, "ready" event not working
    vpxav Level 1
      Hello,
      I have a problem, if I use this code:
      <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" layout="vertical" creationComplete="initM1()">
          <mx:Script>
               <![CDATA[
                   import mx.controls.Label;
                   public var myVar:myModule;
                  private function initM1():void{
                      myVar = m1.child as myModule;
                      myVar.label1.text="data sent!";
          </mx:Script>
          <mx:Panel width="100%">
              <mx:ModuleLoader id="m1" url="myModule.swf" ready="initM1()"/>
          </mx:Panel>
      </mx:Application>
      the function is not called (I cannot see the module's label1.text changed).
      But if I do this:
      <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute">
          <mx:Script>
               <![CDATA[
                   private var myVar:myModule;
          </mx:Script>
              <mx:ModuleLoader id="m1" url="myModule.swf" />
              <mx:Button click="initM1();"/>
          </mx:Panel>
      </mx:Application>
      the function is called when the button is clicked.
      Why isn't it working with the "ready" event of my ModuleLoader?
      How to correct this?
      Thank you for you help.
        • 1. Re: ModuleLoader, "ready" event not working
          rgadiparthi Level 2
          try
          <mx:ModuleLoader id="m1" url="view.swf" setup="initM1(event)"/>
          • 2. Re: ModuleLoader, "ready" event not working
            Gus187
            You may try adding listeners to the error, progress, setup events and see if any of these can give you more information about why is not calling the ready event.
            HTH Gus
            • 3. Re: ModuleLoader, "ready" event not working
              Gaurav J Adobe Employee
              event handler for ready event expects an event of type ModuleEvent.
              Have you tried:
              <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" layout="vertical" >
                  <mx:Script>
                       <![CDATA[
              import mx.events.MoudleEvent;
                          private function initM1(e:ModuleEvent):void{
                  </mx:Script>
                      <mx:ModuleLoader id="m1" url="myModule.swf" ready="initM1(event)"/>
                  </mx:Panel>
              </mx:Application>
              Gaurav Jain
              Flex SDK Team
              http://www.gauravj.com/blog
              • 4. Re: ModuleLoader, "ready" event not working
                vpxav Level 1
                Hello,
                sorry for the late reply... I was on holiday.
                I thank you very much for your help but the previous tip did not work. Of course, I replaced
                with
                import mx.events.ModuleEvent;
                Might it be because I'm using flex with Eclipse on Linux?
                Thank you.
                • 5. Re: ModuleLoader, "ready" event not working
                  Flex harUI Adobe Employee
                  Are you trying this on a debug player?  I would expect an error.  The child objects of the moduleLoader.child are probably not available when your READY handler is called
                  Alex Harui
                  Flex SDK Developer
                  Adobe Systems Inc.
                  Blog: http://blogs.adobe.com/aharui
                  • 6. Re: ModuleLoader, "ready" event not working
                    vpxav Level 1
                    Hello,
                    I have indeed an error in the debugger;
                    don't know what to do with this error:
                    [SWF] /TESTS/TESTS.swf - 586,250 bytes after decompression
                    [SWF] /TESTS/myModule.swf - 59,200 bytes after decompression
                    TypeError: Error #1009: Cannot access a property or method of a null object reference.
                        at TESTS/initM1()[/home/xavier/workspace/TESTS/src/TESTS.mxml:10]
                        at TESTS/__m1_ready()[/home/xavier/workspace/TESTS/src/TESTS.mxml:15]
                        at flash.events::EventDispatcher/dispatchEventFunction()
                        at flash.events::EventDispatcher/dispatchEvent()
                        at mx.core::UIComponent/dispatchEvent()[E:\dev\3.0.x\frameworks\projects\framework\src\mx\co re\UIComponent.as:9051]
                        at mx.modules::ModuleLoader/moduleReadyHandler()[E:\dev\3.0.x\frameworks\projects\framework\ src\mx\modules\ModuleLoader.as:335]
                        at ModuleInfoProxy/moduleEventHandler()[E:\dev\3.0.x\frameworks\projects\framework\src\mx\mo dules\ModuleManager.as:1027]
                        at ModuleInfo/readyHandler()[E:\dev\3.0.x\frameworks\projects\framework\src\mx\modules\Modul eManager.as:706]
                        at mx.core::FlexModuleFactory/update()[E:\dev\3.0.x\frameworks\projects\framework\src\mx\cor e\FlexModuleFactory.as:325]
                        at mx.core::FlexModuleFactory/docFrameHandler()[E:\dev\3.0.x\frameworks\projects\framework\s rc\mx\core\FlexModuleFactory.as:413]
                    Any idea?
                    • 7. Re: ModuleLoader, "ready" event not working
                      Like I said, the children of the child are not available when the READY event dispatches.  I would use the READY event to hook up a CREATION_COMPLETE handler and call initM1() then.
                      Alex Harui
                      Flex SDK Developer
                      Adobe Systems Inc.
                      • 8. Re: ModuleLoader, "ready" event not working
                        vpxav Level 1
                        Hello, I'm really sorry but I don't understand what I have to do...
                        Here are the two little files I'm using to do this test.
                        Could anyone modify it so that it works. It will be much easier for me to understand.
                        There are only a few lines.
                        Thank you very much.
