3 Replies Latest reply on Sep 23, 2008 10:47 AM by three_penguins
    Images Folder in Project Manager Pod
    three_penguins Level 1
      I've imported some .html files authored in Dreamweaver to RH7. They import fine. When I look at the Images folder in Windows Explorer the image files did import correctly. When I output the files to WebHelp format the images are correctly copied to the output folder. So things are working but...
      Here's the part I don't get. In the Project Manager pod the Images "folder" is empty and there are also no images showing under "Baggage Files". This seem puzzling. Shouldn't imported images show up somewhere in RH?
        • 1. Re: Images Folder in Project Manager Pod
          Hi Esch
          RoboHelp is mad at you for saying you are "stuck" with it, so it's hiding the images!
          Just kidding of course.
          Does your "Images" pseudo-folder list other folders inside? If so, the images may be there. If you are using Dreamweaver, it's a common practice to create a folder named "Images" for a web site and store your image assets there. I'd be double-checking what you see in the Images pseudo-folder and see if you find images inside a folder there.
          Cheers... Rick
          • 2. Re: Images Folder in Project Manager Pod
            Yes, I do use Dreamweaver as my primary editing tool, then import to RH. The pseudo-folder has nothing at all, no sub directories, no files of any kind. The actual folder /images located at the root of the RH project does have all the images. Guess I should just be grateful it works when I compile it as WebHelp and not worry about the pseudo-folder. Just seems like the images should be there and doesn't seem to be a way to manually add them. It doesn't appear that any of the .apj files contain that information.
            • 3. Re: Images Folder in Project Manager Pod
              I just tried closing the RH project and renaming the /images folder so RH would no longer recognize it. Then I opened the RH project and imported another .html page with the same images. RH showed a msgbox saying the names of each .jpg as being successfully imported. RH did recreate the /images folder and the .jpgs are there, yet the pseudo Images folder continues to show nothing.
