4 Replies Latest reply on Jul 18, 2009 8:30 PM by the_wine_snob
    "Premiere Pro CS3" is missing some codecs!
    haromax
      Hi!
      First of all, thanks for stoping by and read my post.
      It's me first time ever using Premiere Pro CS3. I tried to some basic video editing on it, but I cannot hear any sound coming out of my laptop speakers; when i import the video clips. Even tho, I can hear them with "Windows Media Player". So, I investigated a bit and I did some of the things adviced by Adobe's knowledgebase thing.
      And, I came up with a paper saying to download "MediaInfo" and "GSpot" to find out the codecs of the "mpg" files. Here is a report i made with the information given by those programs:
      DVD "VOB" format
      Format: MPEG-PS
      MPEG-2 Program Stream << { 1 vid, 1 aud }
      Sys Bitrate: 10080 kb/s VBR
      Bit rate mode                    : Variable
      bit rate                 : 5 899 Kbps or 5 324 Kbps
      Nominal bit rate                 : 9 100 Kbps
      Width                            : 720 pixels
      Height                           : 480 pixels
      Display aspect ratio             : 16/9
      Frame rate                       : 29.970 fps
      Standard                         : NTSC
      Colorimetry                      : 4:2:0
      Scan type                        : Interlaced
      Scan order                       : Top Field First
      Codec(s) are Installed
      Audio
      Format                           : AC-3
      Format/Info                      : Audio Coding 3 (AC3)
      Bit rate mode                    : Constant
      Bit rate                         : 256 Kbps
      Channel(s)                       : 2 channels
      Channel positions                : L R
      Sampling rate                    : 48.0 KHz
      Resumen:
      0xbd[0x80]:48000Hz  256 kb/s tot , stereo (2/0)
      Codec(s) Installed
      Missing:
      DSH FmtTag: 0x00ff    "MainConcept (Adobe2) AAC Decoder" {214CD0D1-FC06-41B1-8BB8-84DA4CFB17D9} 0x00600000 ** File Missing: "C:\Program Files\Adobe\Adobe Premiere Pro CS3\ad2daac.ax"
      DSH Video "MainConcept (Adobe2) H.264/AVC Decoder" {FF890B41-A4C5-4B19-87CF-65D86EC12F1C} 0x00600000 ** File Missing: "C:\Program Files\Adobe\Adobe Premiere Pro CS3\ad2dsh264.ax"
      DSH MPEG1Packet "MainConcept (Adobe2) MPEG Audio Decoder" {25AD5730-4DE0-4CF8-952A-2AEF53AC4321} 0x005fffff ** File Missing: "C:\Program Files\Adobe\Adobe Premiere Pro CS3\ad2mcdsmpeg.ax"
      DSH MPEG1Packet "MainConcept (Adobe2) MPEG Video Decoder" {25AD5740-4DE0-4CF8-952A-2AEF53AC4321} 0x005fffff ** File Missing: "C:\Program Files\Adobe\Adobe Premiere Pro CS3\ad2mcdsmpeg.ax"
      DSH MPEG1System "MainConcept (Adobe2) MPEG Splitter" {25AD5720-4DE0-4CF8-952A-2AEF53AC4321} 0x005fffff ** File Missing: "C:\Program Files\Adobe\Adobe Premiere Pro CS3\ad2mcspmpeg.ax"
      DSH Video "MainConcept (Adobe2) MPEG Encoder" {25AD5750-4DE0-4CF8-952A-2AEF53AC4321} 0x00200000 ** File Missing: "C:\Program Files\Adobe\Adobe Premiere Pro CS3\ad2mcesmpeg.ax"
      DSH YV12 "MainConcept (Adobe2) H.264 Encoder" {FF890B51-A4C5-4B19-87CF-65D86EC12F1C} 0x00200000 ** File Missing: "C:\Program Files\Adobe\Adobe Premiere Pro CS3\ad2esh264.ax"
      DSH RGB24 "MainConcept (Adobe2) MPEG Video Encoder" {25AD5760-4DE0-4CF8-952A-2AEF53AC4321} 0x00200000 ** File Missing: "C:\Program Files\Adobe\Adobe Premiere Pro CS3\ad2mcevmpeg.ax"
      DSH PCM "MainConcept (Adobe2) MPEG Audio Encoder" {25AD5770-4DE0-4CF8-952A-2AEF53AC4321} 0x00200000 ** File Missing: "C:\Program Files\Adobe\Adobe Premiere Pro CS3\ad2mceampeg.ax"
      DSH MPEG1Video "MainConcept (Adobe2) MPEG Multiplexer" {25AD5780-4DE0-4CF8-952A-2AEF53AC4321} 0x00200000 ** File Missing: "C:\Program Files\Adobe\Adobe Premiere Pro CS3\ad2mcmuxmpeg.ax"
      DSH RGB24 "MainConcept (Adobe2) H.264/AVC Video Encoder" {FF890B61-A4C5-4B19-87CF-65D86EC12F1C} 0x00200000 ** File Missing: "C:\Program Files\Adobe\Adobe Premiere Pro CS3\ad2evh264.ax"
      DSH PCM "MainConcept (Adobe2) AAC Encoder" {866DFE40-5582-4FA6-B4BC-665781A007E6} 0x00100000 ** File Missing: "C:\Program Files\Adobe\Adobe Premiere Pro CS3\ad2eaac.a
      As you can see "Premiere Pro CS3" is missing some codecs, so my question is where can I download those?
      I forgot to tell you, that I use a HP laptop Dual core Intel processor with Win Vista Home 2 GB of RAM and 160 GB of HD
      Thanks in advance
      P.S. I am attaching the Diagdx.txt, even tho I don't think has to necesary
      P.S. 2. I just saw another post similar to this one, but it doesn't tell you how to make "Premiere Pro" get the audio to work in my clips and finished project
