4 Replies Latest reply on Jul 19, 2009 8:48 PM by pixlor
    Sliceing a photo and then rotating it.Maybe with feather.
    JerryCied Level 1
      I have an image 2.5 in wide and 3.5 in high (300 dpi).
      I want to convert this image into a playing card as in a face card.
      The image is a drawing of a king head to toe.
      I want to slice the photo in a diagonal. A diagonal that passes through the exact center of the image.
      I want to throw away the bottom part of the image. I want to copy and rotate 180 degrees the top half to replace the bottom halk i just discared.
      In the end i want the image to be like the king of hearts in a deck of cards.
      Also the line the cuts the original image may be straight accross or at a diagonal. It may also be a symetrical curve that fits into itself after the copy and rotate.
      I cant seem to get past the cut part.
      I have tried polygon lassoo but cant garentee that it passes the exact center.
      I would like to draw a freehand irregular cut and end it on the exact center, then flip the line so that the rest of the line mirors the first halh in such a way as to fit exactly after the cut and rotate.
      I hope i am clear on my question.
      Thank you up front.
      Jerry C
