1 Reply Latest reply on Jul 19, 2009 6:17 AM by Ned Murphy
    Can someone explain the structure behind this common practice in most flash websites?
    MorisatoKei Level 1
      I'm kind of a newbie with flash. I havent used it in a long long time and when I was using it, I wasnt really fully understanding what I was doing at the time. Anyways, it's been like 10 years now and I have to use it to make a website, but I can't figure out how others are doing this specific thing. I understand the basic concept of how flash works with making a website, and I've even built a very basic website with audio/video and mouse interaction, but now I want to step it up. I've seen many flash websites before and some have a lot of things going on at once and I'm wondering how you implement that smoothly while still allowing mouse interaction and navigation. I know this sounds confusing but basically, what I mean is:
      let's say I have a website and on the website I have buttons that lead to different pages(frames) when clicked. On the main page I have something like a bird that flies from left to right. Let's say that the bird is in the middle of the screen and a user clicks a button. How do I make it so that the bird continues to fly off screen before switching pages? Obviously, I cant tell what the location of the bird will be when the button is clicked since it will vary from user to user so I am completely confused on how to structurally set this up. Would the bird be it's own swf embedded in the main swf? Or is this feature a massive keyframing project for every frame of animation that bird has?
      Also, how do have multiple animations that run on different clocks looping simultaneously? What I mean by this is, lets say the previously mentioned bird has a 25 frame animation loop and a second element, like a sunrise/sunset has a 30 frame animation loop... how do I loop both of them so that they loop seemlessly at the same time? Will I have to animate both of them in a loop until both reach a common frame (150 frames from 6x 25frame bird loops and 5x 30frame sunrise/sunset loops)?
      MorisatoKei
        • 1. Re: Can someone explain the structure behind this common practice in most flash websites?
          You will have to experiment to see what works well and what doesn't.   You can have things animating along a timeline in parallel, but you can also have them be their own movieclips and animated when commanded to play().
          In the case of your bird flying off before a button click is processed, you could manage that as follows.  Have the button set a variable that is defaulted at false to be true.  At the end of the bird's flight, you test that variable ( as in ... if(variable == true)...) to see if it is true, and if so, you process whatever command that button is intended for.  If you used a timeline animtion for the bird, then that test would occur at the last frame of the animation.  If you used a coded tween to move the bird across the scene, then you could use an event listener to detect the animation completed and do the test then.
          There are almost always a variety of choices for achieving the same design goal.  The key to determining a solution is knowing what tools you have to work with... and coming to know what those tools are and how to use them is where learning comes in.
