Hi there
I have a cfform that looks at files in a directory. The template is meant to allow users to select a document and and view it on the page.
The relevant code is:
Main Page:
<cfform name = "name">
<cfinput name="displayName" id="displayName" value="#URLEncodedFormat(displayName)#" type="text">
<cfdiv bind="url:/_admin/utilities/viewer/viewer.cfm?displayName={displayName}" />
</cfform>
viewer.cfm
<cfset mimeType = getPageContext().getServletContext().getMimeType(displayName)>
<cfheader name="Content-Disposition" value="inline; filename=#displayName#">
<cfcontent type="#mimeType#" file="#displayName#">
Problem is, the text in the cfDiv appears literally as:
%PDF-1.4 %äüöß 2 0 obj <> stream x��� 5 }���� ����� ����wVI (���*�T٫��J�!��W�����u]� � N���J> �w1������Lek� ���d�\W����dR%3- ��d{@�ȅ��4��G\8!�'��.�� o����� �9ܴ �� �� �����X�������V����ִ�i>��*Y| �͋�"���=o�� .<��7 ��D�ϸ� uӊ��p�-� m�c ����o�i��j���7$TG�M E P� P���QB���A 1�` ��; cS! : c2ċ9�c���.(6�Ċ� ΰ���i7
Is anyone able to make any suggestions? For instance, can this event be done using AJAX tags?
Thanks in advance
Boon
A cfdiv is not a separate browser window. So I do not think you can change the content type mid-stream that way. You might try embedding the pdf with <object>. I think that would work. (Of course that is assuming the user's browser is actually configured to display pdf's within the browser .. )
