2 Replies Latest reply on Oct 12, 2009 12:51 AM by orca.dev0
    BlazeDS deployment on JBoss5
    olegkon Level 1
      I tried to deploy BlazeDS 3.2 to JBoss 5.1.0 by copying the contents
      of tomcat/webapps from Turnkey Testdrive on Tomcat6 to jboss/server/default/deploy on JBoss.
      Restarted JBoss, it showed few exceptions starting from:
      22:13:51,062 ERROR [AbstractKernelController] Error installing to PostClassLoader: name=vfszip:/C:/jboss-5.1.0.GA/server
      /default/deploy/blazeds/WEB-INF/lib/cfgatewayadapter.jar/ state=ClassLoader mode=Manual requiredState=PostClassLoader
      org.jboss.deployers.spi.DeploymentException: Cannot process metadata
              at org.jboss.deployers.spi.DeploymentException.rethrowAsDeploymentException(DeploymentExcept ion.java:49)
              at org.jboss.deployment.AnnotationMetaDataDeployer.deploy(AnnotationMetaDataDeployer.java:18 1)
              at org.jboss.deployment.AnnotationMetaDataDeployer.deploy(AnnotationMetaDataDeployer.java:93 )
              at org.jboss.deployers.plugins.deployers.DeployerWrapper.deploy(DeployerWrapper.java:171)
              at org.jboss.deployers.plugins.deployers.DeployersImpl.doDeploy(DeployersImpl.java:1439)
              at org.jboss.deployers.plugins.deployers.DeployersImpl.doInstallParentFirst(DeployersImpl.ja va:1157)
      Caused by: java.lang.ClassNotFoundException: coldfusion.ColdFusion from BaseClassLoader@1deebc8{VFSClassLoaderPolicy@49c
      ab1{name=vfszip:/C:/jboss-5.1.0.GA/server/default/deploy/blazeds/WEB-INF/lib/cfgatewayadap ter.jar/ domain=ClassLoaderDom
      ain@11a4bd4{name=DefaultDomain parentPolicy=BEFORE parent=org.jboss.bootstrap.NoAnnotationURLClassLoader@1dd7056} roots=
      [MemoryContextHandler@10111856[path= context=vfsmemory://5c4o119-f9t84u-fxckar7w-1-fxckbz1l-28 real=vfsmemory://5c4o119-
      f9t84u-fxckar7w-1-fxckbz1l-28], DelegatingHandler@30326000[path=blazeds/WEB-INF/lib/cfgatewayadapter.jar context=file:/C
      :/jboss-5.1.0.GA/server/default/deploy/ real=file:/C:/jboss-5.1.0.GA/server/default/deploy/blazeds/WEB-INF/lib/cfgateway
      adapter.jar]]  delegates=null exported=[coldfusion.eventgateway.flex.rmi, flex.data.adapters, coldfusion.flex, flex.data
      , META-INF] <IMPORT-ALL>NON_EMPTY}}
              at org.jboss.classloader.spi.base.BaseClassLoader.loadClass(BaseClassLoader.java:448)
              at java.lang.ClassLoader.loadClass(ClassLoader.java:252)
              at org.jboss.deployment.OptAnnotationMetaDataDeployer.processJBossClientMetaData(OptAnnotati onMetaDataDeployer.j
      ava:115)...
      As a result, getting "Unable to connect" on FireFox3.5 http://localhost:8400/
      Is there an instruction how to deploy BlazeDS [or LCDS261] (and its samples) on JBoss5 ?
      I think, even ROOT directories have to be merged (starting from web.xml and index.html).
      Please help !
      Thank you,
      Oleg.
        • 1. Re: BlazeDS deployment on JBoss5
          Rene Szabo Level 1
          Hi, am using BlazeDS for my Thesis, so I think I now.
          The first thing is download the BlazeDS, owns you have the War, now you have to go to you jboss folder and the deploy folder (C:\jboss\server\default\deploy) in here we create a folder named blazeds.war, “yeap, the folders name has a dot” in so now are dir is C:\jboss\server\default\deploy\blazeds.war.
          With the Downloaded War we are going to open it like a RAR, so you right click it and say open with  - > winrar. In the war there is going to be a metadata inf and a web inf and am not sure it something else.
          Dump al the content in the C:\jboss\server\default\deploy\blazeds.war
          There are 2 ways to deploy the java files:
          1. - put all the classes of java in C:\jboss\server\default\deploy\blazeds.war\WEB-INF\classes
          2. - Export all your project like a JAR and put it in C:\jboss\server\default\deploy\blazeds.war\WEB-INF\lib ( THIS IS THE WAY AM DOING IT ) but every time you export the JAR you have to shut down jboss and started again.
          The Flex deploy goes C:\jboss\server\default\deploy\blazeds.war\the_flex_deploy
          If you need the eclipse configurations just mail me or post that you need it.
          Good bye.
          René R. Ramírez S.
          Blog: http://developyourdream.blogspot.com
          Caracas - Venezuela
          • 2. Re: BlazeDS deployment on JBoss5
            orca.dev0
            Hello Olegkon,
            I had the same problem. Did you find any solution ?
