5 Replies Latest reply on Jul 22, 2009 5:40 AM by MergeThis
    Robohelp compilation error
    sonalsurojit
      I am geeting the follwoing error when generating the chm file.
      HHC4001: Warning:
      The following alias line does not contain an '=' character  separating the topic IDs:  .
      BMG_help.hhc
      BMG_help.hhk
      Throttling_Configuration.htm
      SMS_Pull_Application_Management.htm
      SMS_MMS_WAP_Messaging_.htm
      Content_Provider_User_Management.htm
      Quota_Management.htm
      Content_Provider_Group_Account_Management.htm
      Functionality.htm
      Circle_Management.htm
      System_Administration_.htm
      Introduction.htm
      BMG_User_Hierarchy.htm
      Overview.htm
      reference_documents.htm
      Management_of_Services.htm
      acronyms_and_abbreviations.htm
      Multiple_User_Types.htm
      Framework_to_Support_New_Interfaces.htm
      MMS_Pull_Application_Management.htm
      Multiple_Interfaces_Support.htm
      Subscriber_Management.htm
      Web_Interface.htm
      External_Interfaces_Support.htm
      Generation_of_CDRs.htm
      Flexible_Billing_Definitions.htm
      Message_Queuing.htm
      Generation_of_Statistics_.htm
      Subscription_Management.htm
      Traffic_Reports.htm
      Generation_of_Reports_.htm
      Message_Scheduling.htm
      Conversion_to_External_CDR_Format_.htm
      Content_Provider_Profile_Database.htm
      Service_Provisioning.htm
      SNMP_Support_.htm
      Management_of_Distribution_List_.htm
      Push_Message_Flow.htm
      Receiver_Agent.htm
      OAM.htm
      SNMP.htm
      Processing_Agent.htm
      Dispatcher_Agent.htm
      Mediation_Gateway.htm
      CDR_and_Report_Generation.htm
      Law_Enforcement_Agency_(LEA).htm
      Interface_Layers.htm
      Network_Architecture.htm
      Pull_Message_Flow.htm
      Modifying_SMS_Quota.htm
      managing_cp_account_quota_.htm
      managing_cp_administrators.htm
      viewing_content_providers.htm
      modifying_cp_account_configuration.htm
      creating_content_provider.htm
      managing_content_provider_accounts.htm
      modifying_wap_quota.htm
      web-based_operations.htm
      modifying_sms_messaging.htm
      accessing_application.htm
      modifying_mms_quota.htm
      modifying_cp_user_configuration.htm
      managing_cp_users.htm
      Fatal  Error: Unexpected error from Microsoft HTML compiler.
      Finished compiling  HTMLHELP in 39 sec(s)
      Compilation complete.
      why only to these htms i am getting the error?..what needs to be edited inthese htms?
        • 1. Re: Robohelp compilation error
          Amebr-ke0mH4 Level 2
          Perhaps see if this thread helps:
          .chm not compiling
          • 2. Re: Robohelp compilation error
            sonalsurojit Level 1
            This thread has not heped me as i ma not understaning this:
            As a start I'd look at the alias file and add the missing =
            character. and The alias file is the one with an .ali extension. It is a
            text file so you can open it in Notepad and edit and save.
            regards
            prema
            Date: Mon, 20 Jul 2009 19:12:22 -0600
            To: vibhuteprema@hotmail.com
            Subject: Robohelp compilation error
            http://forums.adobe.com/thread/230382
            • 3. Re: Robohelp compilation error
              I'll go through three options listed in the thread as possibilities:
              1. There is an ali file used for context sensitive help, so it should only be necessary to make changes if this is set up for your application.
              The = symbol separates the context (map) id and the help topic. The context id could be a number of things, depending on how your organisation set things up.
              Examples:
                 AUDIT_TRAIL=Audit_Trail\Audit_Trail.htm
                 99187=Audit_Trail\Audit_Trail.htm
              I don't use this myself (we have a custom solution), but possibly there could be an ID without a topic, or a topic without an ID, or maybe spaces either side of the = sign.
              2. The ali file is saved in the wrong format, indicated by the symbols in the error - .
              You would have to open the file and save in in ANSI format. I think you should just be able to open the file in Notepad, Save As and choose the Encoding for it.
              3. The path to the project is too long. If you have a very long directory structure to get to your project, try moving a copy of the project to a directory something like c:\myproject and seeing if the compile works there.
              HTH
              Amebr
              • 4. Re: Robohelp compilation error
                amber,
                after the suggested chnages i am getting the follwoing error:
                C:\BMG Admin Web Operations\!SSL!\Microsoft_HTML_Help\!chm_tmp_folder_1\BMG_help.hhp
                Microsoft HTML Help Compiler 4.74.8702
                Compiling c:\BMG Admin Web Operations\!SSL!\Microsoft_HTML_Help\BMG_help.chm
                BMG_help.hhc
                BMG_help.hhk
                Introduction.htm
                Overview.htm
                Web_Interface.htm
                SNMP_Support_.htm
                Message_Queuing.htm
                Traffic_Reports.htm
                BMG_Message_Flow.htm
                Receiver_Agent.htm
                OAM.htm
                SNMP.htm
                BMG_Components.htm
                Subscriber_Profile_Database.htm
                Viewing_CP_Administrators.htm
                Modifying_Content_Providers.htm
                modifying_wap_privileges.htm
                Creating_CP_Administrators.htm
                modifying_sms_privileges.htm
                modifying_general_privileges.htm
                modifying_privileges.htm
                modifying_mms_privileges.htm
                Editing_CP_Administrators.htm
                modifying_mms_messaging.htm
                modifying_e-mail_to_sms_messaging.htm
                modifying_wap_messaging.htm
                managing_cp_user_quota.htm
                modifying_messaging_configuration.htm
                Creating_CP_Users.htm
                Modifying_Content_Provider_Users.htm
                Finished compiling HTMLHELP in 42 sec(s)
                Prema
                Date: Mon, 20 Jul 2009 23:33:44 -0600
                Examples:
                2. The ali file is save in the wrong format, indicated by the symbols in the error - .
                HTH
                Amebr
                • 5. Re: Robohelp compilation error
                  MergeThis Level 4
                  The path name is still a bit long. Try a new layout that generates to C:\bmg_chm\BMG_help.chm.
                  You'll note that only one other topic was compiled after your changes, so you didn't gain much:
                  Last topic compiled in Instance 1: modifying_cp_user_configuration.htm
                  Last topic compiled in Instance 2: Modifying_Content_Provider_Users.htm
                  Leon
