10 Replies Latest reply on Jul 27, 2009 11:28 PM by Panoma
    settimeout function in flash 10 (linux)
    Panoma
      have a strange problem. I wrote a flex application, which loads images from the local filesystem. There is a function, which checks, whether all images are loaded. I use the settimeout function to test regularely the state the images. If not all images are completed, I use settimeout to call the check function. Sometimes, the check function is not called, although not all images are loaded.
      I put traces in every line. Everything looks fine, but in rare cases, the application stopped working.
      Here is an excerpt of the check function (traces removed):
         private function CheckImagesLoaded():void {
            clearTimeout(TimeoutId);
            var _LoadedImages:int=0;
             //check images
            if (myLogo._Loaded==true) {
              _LoadedImages++;
            else {
              if (myLogo._Error!="") {
                trace(myLogo._Error);
            //check of other images...
            if (_LoadedImages<_MaxImages) {
              TimeoutId=setTimeout(CheckImagesLoaded, 50);
            else {
              //start application
      Remark: myLogo is a class, the Event.COMPLETE Handler sets the Boolean Flag _Loaded to true, if the image is loaded.
