0 Replies Latest reply on Jul 20, 2009 7:06 AM by Paul Reilly
    [svn:fx-trunk] 8682: * Made compile time metadata inheritable and made Bindable inherited.
    Paul Reilly Level 1
      Revision: 8682
      Author:   preilly@adobe.com
      Date:     2009-07-20 07:05:56 -0700 (Mon, 20 Jul 2009)
      Log Message:
      • Made compile time metadata inheritable and made Bindable inherited.
        This means it's no longer necessary to copy Bindable metadata down
        to overridden variables and properties.
      tests Passed: checkintests, mxunit databinding
      Needs QA: YES
      Needs DOC: YES
      Bug fixes: SDK-14251
      API Change: NO
      Reviewer: Peter D.
      Is noteworthy for integration: YES
      Code-level description of changes:
        abc/Assignable.java
        as3/reflect/Assignable.java
          Initial checkin.
        CompilerAPI.java
          Modified compile() by removing cleanClassTable() call.
        abc/Method.java
        abc/Variable.java
          Modified interface to extend Assignable and removed getQName(),
          getDeclaringClass(), getAttributes(), getMetaData(), and
          getMetaData(String).
        abc/AbcCompiler.java
          Modified analyze4() to no longer set the typeTable of the AbcClass
          since we no longer null it out in CompilerAPI.compile().
        as3/reflect/Method.java
        as3/reflect/Variable.java
          Modified class to extend Assignable.
          Removed getQName(), getDeclaringClass(), getAttributes(),
          getMetaData(), and getMetaData(String).
          Added getOverridden().
        as3/reflect/TypeTable.java
          Made createMethod() and createVariable() non-static.
        as3/reflect/As3Class.java
          Updated to reflect TypeTable changes.
        as3/AbstractSyntaxTreeUtil.java
          Updated generateApplyTypeExpr() to include "*".
          Modified generateTypeExpression() by adding includeAnyType parameter.
        as3/binding/DataBindingFirstPassEvaluator.java
        as3/binding/TypeAnalyzer.java
        mxml/reflect/TypeTable.java
          Modified all getMetaData() calls to include inherited metadata.
        SymbolTable.java
          Removed cleanClassTable().
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-14251
      Modified Paths:
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/CompilerAPI.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/SymbolTable.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/abc/AbcCompiler.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/abc/Method.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/abc/Variable.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/AbstractSyntaxTreeUtil.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/binding/DataBindingFirstPassE valuator.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/binding/TypeAnalyzer.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/reflect/As3Class.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/reflect/Method.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/reflect/TypeTable.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/reflect/Variable.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/reflect/TypeTable.java
      Added Paths:
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/abc/Assignable.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/reflect/Assignable.java
