2 Replies Latest reply on Jul 20, 2009 10:45 AM by GaryNY
    Subtracting/adding a number of business days ??
    GaryNY
      Hi everyone !
      I have a calendar question: I have a date, number of days (either business or calendar) and Before/After indicator.
      I need to calculate the future/past date depending on business/calendar nn days.
      Ideally, I will also read Holidays table to fix the result with Holidays.
      Any suggestions ?
      CF allows me to know a weekday, add/subtract units from dates, compare dates, but nothing in the direction I mentioned...
      Any suggestions will be greatly appreciated !
      Gary.
        • 1. Re: Subtracting/adding a number of business days ??
          Dan Bracuk Level 5
          put a table in your db that has the date as the primary key, a business day field, and anything else that's relevent to your organization.  Give the business day field a value of 0 or 1.
          Then, the number of business days between 2 dates is
          select sum(business_day)
          from your table
          where the date between date1 and date2
          to find the date which is x business days from date 1
          <cfset y = 2 * x>
          select date2 from
          <cfloop from = "1" to ="y" index ="ii">
          select dateadd(day, ii, date1) date2, sum(business_day) busdays
          from your table
          group by date2
          union
          </cfloop>
          select distinct date1 date2, 0 busdays
          from yourtable
          ) sq
          where busdays = x
          syntax is db specific of course.
          • 2. Re: Subtracting/adding a number of business days ??
            GaryNY Level 1
            Hi !
            Thank you very much, but I would rather not support business days table
            every year...
            Even Holidays table will be created as a temporary measure: I'll need to
            find a way to automatically download the Holidays.
            But for the business days, I would rather rely on an algorithm, which
            calculates the resulting date with:
            start date,
            After/Before indicator,
            Business/Calendar days indicator,
            Number of days.
            Best regards,
            Gary.
