0 Replies Latest reply on Jul 20, 2009 12:06 PM by Paul Reilly
    [svn:fx-trunk] 8689: * Committing customer patch.
    Paul Reilly
      Revision: 8689
      Author:   preilly@adobe.com
      Date:     2009-07-20 12:06:08 -0700 (Mon, 20 Jul 2009)
      Log Message:
      • Committing customer patch.
      tests Passed: checkintests
      Needs QA: YES
      Needs DOC: NO
      Bug fixes: SDK-20569
      API Change: NO
      Reviewer: me
      Is noteworthy for integration: No
      Code-level description of changes:
        modules/compiler/src/java/flex2/tools/oem/Application.java
        modules/compiler/src/java/flex2/tools/oem/Library.java
        modules/compiler/src/java/flex2/tools/Compc.java
        modules/compiler/src/java/flex2/tools/WebTierAPI.java
        modules/compiler/src/java/flex2/tools/Mxmlc.java
        modules/compiler/src/java/flex2/tools/Fcsh.java
        modules/compiler/src/java/flex2/compiler/asdoc/AsDocAPI.java
          Removed adding of the SourcePath to the thread local path
          resolver.
        modules/compiler/src/java/flex2/compiler/CompilerAPI.java
          Modified compile() to add the SourcePath to the thread local path
          resolver.
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-20569
      Modified Paths:
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/CompilerAPI.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/asdoc/AsDocAPI.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/Compc.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/Fcsh.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/Mxmlc.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/WebTierAPI.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/oem/Application.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/oem/Library.java
