1 Reply Latest reply on Jul 20, 2009 3:52 PM by Flex harUI
    Binding - the best practices
    christoferek Level 1
      Hi All,
      I have 2 files:
      1. application.mxml where I want to display some variables (properties) from the second file. I will display those variables mainly as debugging infos. I will mainly use <mx:Label> tags.
      2. file.as is a class and the properties will have to be displayed in application.mxml. The instances of the class will be created during run time and not at the start.
      My question is: How do I do this? I know that binding variables is the solution to this problem. Can you give me a clue and some direction how I start with it? Perhaps some working example will be a good start.
      This is common problem I think, but I spent the whole day on studying lots of examples and I am confused now.
      Best Regards
      Chris
        • 1. Re: Binding - the best practices
          Flex harUI Adobe Employee
          If File.as looks like this:
          public class File
               public var name:String = "foo";
          You can get it in your app like this:
          <mx:Application>
          <mx:Script>
          <![CDATA[
               private var aFile:File;
          </mx:Script>
          <mx:Label text="{aFile.name}" />
          </mx:Application>
          Add some code to set aFile = new File() and you should see "foo" in the label
          Alex Harui
          Flex SDK Developer
          Adobe Systems Inc.
          Blog: http://blogs.adobe.com/aharui
