2 Replies Latest reply on Jul 21, 2009 5:47 PM by Panos Zygopoulos
    Wrong export using css images (Divs)
    Tom Adobe Level 1
      Hi
      I'm working in a website project with Fireworks CS4 v.10.0.311  (I applied FW update 10.0.311 only from 10.0.0) under Mac OS X 10.5.7 on Mac Pro 3.2 GHZ with 32 GB of RAM and export the project from Fireworks to use in Dreamweaver CS4 using File/export/css images to get a final html file with images using Div Tags as structure but doesn't works properly because block content (Div tags) are not in place and are messy when I see in DW Design View or rendering in any browser.
      If I use FW Export Wizard then got this error message:
      file <startup disk>:Applications:Adobe Fireworks
      CS4:Configuration:HTML Code.CssLayers.htt,line 1401,
      error:test for equality (==) mistyped as assignment (=)?
      Assuming equality test
      If I export using tables (HTML and Images - Export HTML File - Export Slices) then it export properly but don't want tables, I want DIVs Tag for work and Fireworks CSS Images export option only.
      Please, check the attach file named "wrong-export-css-images.zip" it's a Fireworks's PNG with slicing and is one page of my project that gives this error.
      Someone can help me to get a final DIV structure HTML file with CSS and images in a correct way?
      Thank you
      Tom
