0 Replies Latest reply on Jul 20, 2009 7:15 PM by jmurphy67
    [svn:fx-trunk] 8702: -add textLayout source project to trunk
    jmurphy67 Level 1
      Revision: 8702
      Author:   jimurphy@adobe.com
      Date:     2009-07-20 19:15:02 -0700 (Mon, 20 Jul 2009)
      Log Message:
      -to build from frameworks/build.xml: ant tlf
      -removed in/tlf directory, no more pre-built tlf
      -updated debug value in the main build.xml to false
      qa: yes
      doc: probably
      checkintests: pass
      Modified Paths:
          flex/sdk/trunk/build.xml
          flex/sdk/trunk/frameworks/build.xml
          flex/sdk/trunk/frameworks/libs/textLayout.swc
      Added Paths:
          flex/sdk/trunk/frameworks/projects/textLayout/
          flex/sdk/trunk/frameworks/projects/textLayout/build.xml
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_conversion/
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_conversion/src/
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_conversion/src/flashx/
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_conversion/src/flashx/textLayout /
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_conversion/src/flashx/textLayout /ConversionClasses.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_conversion/src/flashx/textLayout /conversion/
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_conversion/src/flashx/textLayout /conversion/BaseTextLayoutExporter.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_conversion/src/flashx/textLayout /conversion/BaseTextLayoutImporter.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_conversion/src/flashx/textLayout /conversion/ConversionType.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_conversion/src/flashx/textLayout /conversion/CustomFormatImporter.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_conversion/src/flashx/textLayout /conversion/FlowElementInfo.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_conversion/src/flashx/textLayout /conversion/HtmlExporter.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_conversion/src/flashx/textLayout /conversion/HtmlImporter.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_conversion/src/flashx/textLayout /conversion/IFormatImporter.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_conversion/src/flashx/textLayout /conversion/ITextExporter.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_conversion/src/flashx/textLayout /conversion/ITextImporter.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_conversion/src/flashx/textLayout /conversion/ImportExportConfiguration.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_conversion/src/flashx/textLayout /conversion/PlainTextExporter.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_conversion/src/flashx/textLayout /conversion/PlainTextImporter.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_conversion/src/flashx/textLayout /conversion/SingletonAttributeImporter.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_conversion/src/flashx/textLayout /conversion/TLFormatImporter.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_conversion/src/flashx/textLayout /conversion/TextConverter.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_conversion/src/flashx/textLayout /conversion/TextLayoutExporter.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_conversion/src/flashx/textLayout /conversion/TextLayoutImporter.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/manifest.xml
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/Build Info.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/CoreC lasses.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/acc/
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/acc/T extAccImpl.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/compo se/
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/compo se/BaseCompose.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/compo se/ComposeState.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/compo se/FlowComposerBase.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/compo se/FlowDamageType.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/compo se/IFlowComposer.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/compo se/IParcelList.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/compo se/ITextLineCreator.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/compo se/IVerticalJustificationLine.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/compo se/Parcel.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/compo se/ParcelList.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/compo se/SimpleCompose.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/compo se/StandardFlowComposer.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/compo se/TextFlowLine.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/compo se/TextFlowLineLocation.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/compo se/TextLineRecycler.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/compo se/VerticalJustifier.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/conta iner/
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/conta iner/ColumnState.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/conta iner/ContainerController.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/conta iner/ISandboxSupport.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/conta iner/ScrollPolicy.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/debug /
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/debug /Debugging.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/debug /assert.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/edit/
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/edit/ EditingMode.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/edit/ IInteractionEventHandler.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/edit/ ISelectionManager.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/edit/ SelectionFormat.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/edit/ SelectionState.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/eleme nts/
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/eleme nts/BackgroundManager.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/eleme nts/BreakElement.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/eleme nts/Configuration.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/eleme nts/ContainerFormattedElement.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/eleme nts/DivElement.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/eleme nts/FlowElement.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/eleme nts/FlowGroupElement.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/eleme nts/FlowLeafElement.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/eleme nts/FlowValueHolder.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/eleme nts/IConfiguration.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/eleme nts/IFormatResolver.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/eleme nts/InlineGraphicElement.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/eleme nts/InlineGraphicElementStatus.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/eleme nts/LinkActiveFormat.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/eleme nts/LinkElement.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/eleme nts/LinkHoverFormat.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/eleme nts/LinkNormalFormat.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/eleme nts/LinkState.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/eleme nts/OverflowPolicy.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/eleme nts/ParagraphElement.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/eleme nts/ParagraphFormattedElement.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/eleme nts/SpanElement.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/eleme nts/SpecialCharacterElement.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/eleme nts/SubParagraphGroupElement.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/eleme nts/TCYElement.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/eleme nts/TabElement.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/eleme nts/TextFlow.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/eleme nts/TextRange.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/event s/
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/event s/CompositionCompleteEvent.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/event s/DamageEvent.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/event s/FlowElementMouseEvent.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/event s/ModelChange.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/event s/StatusChangeEvent.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/event s/TextLayoutEvent.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/event s/UpdateCompleteEvent.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/exter nal/
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/exter nal/WeakRef.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/facto ry/
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/facto ry/StringTextLineFactory.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/facto ry/TextFlowTextLineFactory.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/facto ry/TextLineFactoryBase.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/facto ry/TruncationOptions.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/forma ts/
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/forma ts/BackgroundColor.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/forma ts/BaselineOffset.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/forma ts/BaselineShift.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/forma ts/BlockProgression.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/forma ts/Category.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/forma ts/Direction.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/forma ts/Float.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/forma ts/FlowElementDisplayType.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/forma ts/FormatValue.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/forma ts/ITabStopFormat.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/forma ts/ITextLayoutFormat.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/forma ts/JustificationRule.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/forma ts/LeadingModel.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/forma ts/LineBreak.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/forma ts/TLFTypographicCase.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/forma ts/TabStopFormat.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/forma ts/TabStopFormatInc.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/forma ts/TextAlign.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/forma ts/TextDecoration.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/forma ts/TextJustify.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/forma ts/TextLayoutFormat.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/forma ts/TextLayoutFormatInc.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/forma ts/TextLayoutFormatValueHolder.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/forma ts/VerticalAlign.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/forma ts/WhiteSpaceCollapse.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/prope rty/
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/prope rty/ArrayProperty.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/prope rty/BooleanProperty.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/prope rty/EnumStringProperty.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/prope rty/IntProperty.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/prope rty/IntWithEnumProperty.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/prope rty/NumberOrPercentOrEnumProperty.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/prope rty/NumberOrPercentProperty.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/prope rty/NumberProperty.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/prope rty/NumberWithEnumProperty.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/prope rty/Property.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/prope rty/StringProperty.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/prope rty/TabStopsProperty.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/prope rty/UintProperty.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/prope rty/UintWithEnumProperty.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/tlf_i nternal.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/utils /
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/utils /CharacterUtil.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/utils /GeometryUtil.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/utils /LocaleUtil.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_edit/
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_edit/manifest.xml
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_edit/src/
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_edit/src/flashx/
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_edit/src/flashx/textLayout/
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_edit/src/flashx/textLayout/EditC lasses.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_edit/src/flashx/textLayout/conta iner/
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_edit/src/flashx/textLayout/conta iner/TextContainerManager.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_edit/src/flashx/textLayout/edit/
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_edit/src/flashx/textLayout/edit/ EditManager.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_edit/src/flashx/textLayout/edit/ ElementRange.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_edit/src/flashx/textLayout/edit/ IEditManager.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_edit/src/flashx/textLayout/edit/ Mark.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_edit/src/flashx/textLayout/edit/ ParaEdit.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_edit/src/flashx/textLayout/edit/ SelectionFormatState.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_edit/src/flashx/textLayout/edit/ SelectionManager.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_edit/src/flashx/textLayout/edit/ TextClipboard.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_edit/src/flashx/textLayout/edit/ TextFlowEdit.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_edit/src/flashx/textLayout/edit/ TextScrap.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_edit/src/flashx/textLayout/event s/
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_edit/src/flashx/textLayout/event s/FlowOperationEvent.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_edit/src/flashx/textLayout/event s/SelectionEvent.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_edit/src/flashx/textLayout/opera tions/
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_edit/src/flashx/textLayout/opera tions/ApplyElementIDOperation.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_edit/src/flashx/textLayout/opera tions/ApplyElementStyleNameOperation.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_edit/src/flashx/textLayout/opera tions/ApplyElementUserStyleOperation.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_edit/src/flashx/textLayout/opera tions/ApplyFormatOperation.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_edit/src/flashx/textLayout/opera tions/ApplyFormatToElementOperation.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_edit/src/flashx/textLayout/opera tions/ApplyLinkOperation.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_edit/src/flashx/textLayout/opera tions/ApplyTCYOperation.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_edit/src/flashx/textLayout/opera tions/CompositeOperation.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_edit/src/flashx/textLayout/opera tions/CutOperation.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_edit/src/flashx/textLayout/opera tions/DeleteTextOperation.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_edit/src/flashx/textLayout/opera tions/FlowElementOperation.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_edit/src/flashx/textLayout/opera tions/FlowOperation.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_edit/src/flashx/textLayout/opera tions/FlowTextOperation.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_edit/src/flashx/textLayout/opera tions/InsertInlineGraphicOperation.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_edit/src/flashx/textLayout/opera tions/InsertTextOperation.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_edit/src/flashx/textLayout/opera tions/ModifyInlineGraphicOperation.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_edit/src/flashx/textLayout/opera tions/PasteOperation.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_edit/src/flashx/textLayout/opera tions/RedoOperation.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_edit/src/flashx/textLayout/opera tions/SplitParagraphOperation.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_edit/src/flashx/textLayout/opera tions/UndoOperation.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_edit/src/flashx/textLayout/utils /
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_edit/src/flashx/textLayout/utils /NavigationUtil.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_edit/src/flashx/undo/
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_edit/src/flashx/undo/IOperation. as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_edit/src/flashx/undo/IUndoManage r.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_edit/src/flashx/undo/UndoManager .as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_textField/
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_textField/src/
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_textField/src/flashx/
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_textField/src/flashx/textLayout/
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_textField/src/flashx/textLayout/ TextFieldClasses.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_textField/src/flashx/textLayout/ controls/
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_textField/src/flashx/textLayout/ controls/TLFTextField.as
          flex/sdk/trunk/frameworks/projects/textLayout/tlf.properties
      Removed Paths:
          flex/sdk/trunk/in/tlf/
