1 Reply Latest reply on Jul 21, 2009 1:34 AM by ma.tze
    "Silent" compile fail, compile aborts after about 11% showing the old result in Brower
    ma.tze Level 1
      it happens again and again, that I am getting compile error, when I am starting to work on my project.
      I stopped yesterday and everything compiled successfully.
      Today I started and changed some code. But the compile aborts after about 11% and the old version ( without the code changes) starts and shown in the browser.
      I do not get a error message in the console, but I can see that for example the changes in a label is not shown in the Browser.
      The following does not help:
      - clean compile ( of project of alls projects)
      - I deleted everything in project-debug folder. I was replaced by the "old" version. Where does that come fro?
      - restarting eclipse
      - restarting vista sp2
      - deactivating the virus scanner (Kaspersky)
      After noticing that thesome is wrong I checked the error messages, see result below.
      I am using FB4b1 stand alone with lcds3b1 on Vista Sp2 with jdk1.6.0_14
      I had that now for the last about 6 weeks! After some time it suddenly works again, after restarting eclipse and the system, but sometimes only in changing some code.
      This behavior costs a lot of time, any help is very appreciated!
      Martin Zach
      Error messages from log:
      !SESSION 2009-07-21 09:29:48.002 -----------------------------------------------
      eclipse.buildId=unknown
      java.version=1.5.0_11
      java.vendor=Sun Microsystems Inc.
      BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
      Command-line arguments:  -os win32 -ws win32 -arch x86 -clean
      !ENTRY com.adobe.flexbuilder.DCDService 4 1 2009-07-21 09:30:05.396
      !MESSAGE Plug-in "com.adobe.flexbuilder.services.BlazeDSService" was unable to instantiate class "com.adobe.flexbuilder.services.blazedsservice.BlazeDSServiceWizard".
      !STACK 1
      org.eclipse.core.runtime.CoreException: Plug-in "com.adobe.flexbuilder.services.BlazeDSService" was unable to instantiate class "com.adobe.flexbuilder.services.blazedsservice.BlazeDSServiceWizard".
           at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.throwException(RegistryStrategyOSGI.java:180)
           at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:174)
           at org.eclipse.core.internal.registry.ExtensionRegistry.createExecutableExtension(ExtensionRegistry.java:867)
           at org.eclipse.core.internal.registry.ConfigurationElement.createExecutableExtension(ConfigurationElement.java:243)
           at org.eclipse.core.internal.registry.ConfigurationElementHandle.createExecutableExtension(ConfigurationElementHandle.java:51)
           at com.adobe.flexbuilder.DCDService.DCDServicePlugin.registerServerTypeInfoForServiceExtensions(DCDServicePlugin.java:70)
           at com.adobe.flexbuilder.DCDService.DCDServicePlugin.start(DCDServicePlugin.java:47)
           at org.eclipse.osgi.framework.internal.core.BundleContextImpl$2.run(BundleContextImpl.java:1009)
           at java.security.AccessController.doPrivileged(Native Method)
           at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:1003)
           at org.eclipse.osgi.framework.internal.core.BundleContextImpl.start(BundleContextImpl.java:984)
           at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:346)
           at org.eclipse.osgi.framework.internal.core.AbstractBundle.start(AbstractBundle.java:265)
           at org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java:400)
           at org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:111)
           at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClass(ClasspathManager.java:427)
           at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.findLocalClass(DefaultClassLoader.java:193)
           at org.eclipse.osgi.framework.internal.core.BundleLoader.findLocalClass(BundleLoader.java:368)
           at org.eclipse.osgi.framework.internal.core.SingleSourcePackage.loadClass(SingleSourcePackage.java:33)
           at org.eclipse.osgi.framework.internal.core.BundleLoader.findClassInternal(BundleLoader.java:441)
           at org.eclipse.osgi.framework.internal.core.BundleLoader.findClass(BundleLoader.java:397)
           at org.eclipse.osgi.framework.internal.core.BundleLoader.findClass(BundleLoader.java:385)
           at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:87)
           at java.lang.ClassLoader.loadClass(Unknown Source)
           at java.lang.ClassLoader.loadClassInternal(Unknown Source)
           at com.adobe.model.fb.extensions.FiberStartupInitializer.earlyStartup(FiberStartupInitializer.java:11)
           at org.eclipse.ui.internal.EarlyStartupRunnable.runEarlyStartup(EarlyStartupRunnable.java:87)
           at org.eclipse.ui.internal.EarlyStartupRunnable.run(EarlyStartupRunnable.java:66)
           at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
           at org.eclipse.ui.internal.Workbench$54.run(Workbench.java:2169)
           at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
      Caused by: java.lang.ExceptionInInitializerError
           at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
           at sun.reflect.NativeConstructorAccessorImpl.newInstance(Unknown Source)
           at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(Unknown Source)
           at java.lang.reflect.Constructor.newInstance(Unknown Source)
           at java.lang.Class.newInstance0(Unknown Source)
           at java.lang.Class.newInstance(Unknown Source)
           at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:170)
           ... 29 more
      Caused by: java.lang.NullPointerException
           at org.eclipse.jface.resource.JFaceResources.getResources(JFaceResources.java:207)
           at org.eclipse.jface.resource.ImageRegistry.<init>(ImageRegistry.java:152)
           at org.eclipse.jface.resource.ImageRegistry.<init>(ImageRegistry.java:124)
           at com.adobe.flexbuilder.services.blazedsservice.BlazeDSServiceWizard.<clinit>(BlazeDSServiceWizard.java:39)
           ... 36 more
      !SUBENTRY 1 org.eclipse.equinox.registry 4 1 2009-07-21 09:30:05.396
      !STACK 0
           ... 36 more
