0 Replies Latest reply on Jul 21, 2009 4:35 AM by Sanjay Kumar Singh
    Seperate DVD installation but play from common interface
    Sanjay Kumar Singh
      I need to develop an application that comprises of several lessons, each lesson installable from seperate DVD's
      All the lessons should play from a common interface(Player)
      Option to update the player and lessons online
      For example, when the user installs the lesson3 DVD, it checks for the player, if not present installs it, and then installs the lesson3 assets
      Then if he installs lesson1, it checks for the presence of the player, if present installs only the lessons1 assets
      Similarly for all the lessons
      All the lessons should be run from a single AIR player, with icons representing all the installed levels in the main menu
      - Install the player in the program files and the various levels assets into the application data folder
           Is this possible to install assets into the application data
      - Install player and assets into program files
           The issue is if the lesson3 is installed in C drive and lesson1 in D:, how do we track and display.
           Is it possible to force the user to install in the default folder
           Is it possible to update any xml to add the installed level name, so as for the player to use when launching
      What would be the best approach
