8 Replies Latest reply on Jul 22, 2009 1:08 PM by fox.hunter
    Error installing Premiere Pro CS4 trial version
    fox.hunter Level 1
      Hi all,
      i've just downloaded Premiere Pro CS4 for testing.
      During installation the files were extracted and setup was starting. But after the system check the installer says that an error occured and that i have to look in the log file. So i'm not able to install the trial.
      Any ideas?
      It can't be a problem of the installer, i've downloaded the sources twice.
      Last part of my log file:
      2009-07-21 13:47:28 [5704]  AFL: AFL2Impl::InsertLEIdIntoMap ENDED stat = 1
      2009-07-21 13:47:28 [5704]  AFL: AFL2Impl::DoDFS STARTED LE=PremiereProApp-CS4-Win-GM
      2009-07-21 13:47:28 [5704]  AFL: AFL2Impl::IsSerialNumberPresent STARTED
      2009-07-21 13:47:28 [5704]  AFL: AFL2Impl::Checking PremiereProApp-CS4-Win-GM Payloadcode
      2009-07-21 13:47:28 [5704]  PCDService: Master PCD doesn't exist. (Errno = 3)
      2009-07-21 13:47:28 [5704]  AFL: AFL2Impl::IsSerialNumberPresent ENDED
      2009-07-21 13:47:28 [5704]  AFL: AFL2Impl::DoDFS ENDED stat = 10
      2009-07-21 13:47:28 [5704]  AFL: AFL2Impl::CheckNonTrialSerialNumber ENDED
      2009-07-21 13:47:28 [5704]  AFL: AFL2Impl::freeAULResources STARTED
      2009-07-21 13:47:28 [5704]  AFL: AFL2Impl::freeAULResources ENDED
      2009-07-21 13:47:28 [5704]  AFL: afl_sa_check_nontrial_parent_serialnumber STOPPED 33
      2009-07-21 13:47:28 [5704]  AFL: Releasing Logger
      Any ideas?
