0 Replies Latest reply on Jul 21, 2009 7:18 AM by obourdon38
    Potential issue with URLRequest and events on MacOS platform
    obourdon38
      I have a problem using URLRequest and events but only on MacOS platform
      tried the exact same air file and perl examples on Linux (Fedora) and they work perfectly well
      as well as on Windows
      The perl client program require active perl 5.10 from ActiveState
      ActivePerl-5.10.0.1005-darwin-9.6.0-290470.dmg
      the source of my examples can be found at
      EventPb.tgz
      or attached to this message
      to verify that everything is fine on your system just launch the perl server and client in another window
      perl EventTestServer.pl
      Entering server loop
      Waiting on 0.0.0.0:7788
      New connection received on 127.0.0.1 from 127.0.0.1
      IO::Socket::INET=GLOB(0x86136c) GOT GET /test/1 HTTP/1.1
      Answering to 1
      Flushing to 1
      Done to 1
      IO::Socket::INET=GLOB(0x861360) GOT GET /test/10 HTTP/1.1
      Answering to 10
      Flushing to 10
      Done to 10
      ^C
      ============================================================== END OF SERVER
      /usr/local/ActivePerl-5.10/bin/perl EventTestClients.pl
      Launching client 1 (1)
      Sending data
      Received  <HTTP/1.1 200 OK
      Date: Tue, 21 Jul 2009 09:23:09 GMT
      Last-modified: Mon, 20 Jul 2009 09:18:11 GMT
      Content-type: application/xml
      Etag: "fb19761e968628212bba247d056fad4e"
      Transfer-encoding: chunked
      End of conversation
      Closing connection
      Launching client 10 (1)
      Current: 2 Running: 1 Joinable: 1
      Sending data
      End of conversation
      Closing connection
      Ending threads=SCALAR(0x81bbc0) > 1
      Current: 1 Running: 0 Joinable: 1
      Ending threads=SCALAR(0x82d610) > 1
      All done
      ============================================================== END OF CLIENT
      let the server run an use the Flex code and click on the ok button
      as soon as the server closes the connection the Flex application runs into trapped error:
      [URLRequestBuilder] Open: [Event type="open" bubbles=false cancelable=false eventPhase=2]
      [URLRequestBuilder] ioErrorHandler: [IOErrorEvent type="ioError" bubbles=false cancelable=false eventPhase=2 text="Error #2032: Stream Error. URL: http://localhost:7788/test/Y" errorID=2032]
      [YDelegate] Return code is: -1
      [EdiXCommand] Fault Y Return code is: -1
      setErrorMsg
      tracing of network packets using WireShark shows that the 200 OK HTTP response has been sent but not received by the
      URL Flex code
      Once again on another platform this runs fine and the flex trace I get is on linux:
      more ~/.macromedia/Flash_Player/Logs/flashlog.txt
      [MyFrontController]: new
      [MyFrontController]: init
      [MAIN]: init
      [MAIN]: clicked on item
      [EditXEvent]: new
      [EditXCommand] new
      [EditXCommand] User wishes to edit X
      [URLRequestBuilder] CONSTRUCTOR
      [URLRequestBuilder] contentType
      [URLRequestBuilder] uri
      [URLRequestBuilder] getRootURL
      [URLRequestBuilder] method
      [YDelegate] Sending request: Y
      [URLRequestBuilder] send
      [URLRequestBuilder] return code: 200
      [URLRequestBuilder] response headers:
      [URLRequestBuilder] HEADER => Date : Tue, 21 Jul 2009 09:23:09 GMT
      [URLRequestBuilder] HEADER => Last-modified : Mon, 20 Jul 2009 09:18:11 GMT
      [URLRequestBuilder] HEADER => Content-type : application/xml
      [URLRequestBuilder] HEADER => Etag : "fb19761e968628212bba247d056fad4e"
      [URLRequestBuilder] HEADER => Transfer-encoding : chunked
      [YDelegate] Return code is: 200
      [YDelegate] SUCCESS code is: 200
      [EditXCommand] Y Received
      Note also that the perl programs run perfectly indentically on Linux and MacOS therefore eliminating the potentiality of TCP
      implementation errors
      Thanks for any help
