7 Replies Latest reply on Jul 23, 2009 10:07 AM by Flex harUI
    Update DataGrid!
    Vitor Wsis
      I have this code on the first component file:
      <mx:HBox xmlns:mx="http://www.adobe.com/2006/mxml" backgroundColor="#525050"
          horizontalGap="4" xmlns:components="components.*">
      <mx:Script>
          <![CDATA[
              import mx.core.Container;
              import valueObjects.UserObject;
              import events.UserEvent;
              [Bindable]
              private var selectedUser:UserObject;
              private function selectUserEventHandler(event:UserEvent):void{
                  selectedUser = event.user;
                  ConfContent.selectedChild=cpUpdateUtilizador;
              private function Menu(op:Container):void{
                  ConfContent.selectedChild=op;
      </mx:Script>
          <mx:Canvas width="150" height="100%" backgroundColor="#C6C6C6">
              <mx:Label x="20" y="20" text="Utilizadores"/>
              <mx:LinkButton x="27" y="37" label="Adiccionar" click="Menu(cpfrmUtilizador)"/>
              <mx:LinkButton x="27" y="55" label="Listagem" click="Menu(cpListaUtilizadores)"/>
          </mx:Canvas>
          <mx:ViewStack id="ConfContent" width="100%" height="100%" backgroundColor="#E8EAEB" selectedIndex="2">
              <components:frmUtilizadores id="cpfrmUtilizador"/>
              <components:updateUtilizador id="cpUpdateUtilizador" selectedUser="{selectedUser}"/>
              <components:listaUtilizadores id="cpListaUtilizadores" selectUserEvent="selectUserEventHandler(event)"/>
          </mx:ViewStack>
      </mx:HBox>
      The second component file is a dataGrid with the follow code:
      <mx:Script>
          <![CDATA[
              [Bindable]
      </mx:Script>
          </mx:Canvas>
          </mx:ViewStack>
      </mx:HBox>
      When i update the Database with new data, i have to RUN again the project because the data on DataGrid isn't updated with a browser refresh, or with a click on the "<mx:LinkButton x="27" y="55" label="Listagem" click="Menu(cpListaUtilizadores)"/>".
      Can you help me?
        • 1. Re: Update DataGrid!
          Flex harUI Adobe Employee
          Where's the database?  Is it on a server?  How do the updates get back to the DataGrid?
          Alex Harui
          Flex SDK Developer
          Adobe Systems Inc.
          Blog: http://blogs.adobe.com/aharui
          • 2. Re: Update DataGrid!
            Vitor Wsis Level 1
            The database is on a MySql Server.
            The code that updates the server is the folowing:
            <mx:VBox xmlns:mx="http://www.adobe.com/2006/mxml" paddingLeft="15" width="100%" height="100%" paddingRight="15"
                            hideEffect="" showEffect="" >
            <mx:Dissolve id="dissolveOut" duration="200" alphaFrom="1.0" alphaTo="0.0"/>
            <mx:Dissolve id="dissolveIn" duration="200" alphaFrom="0.0" alphaTo="1.0"/>
            <mx:Script>
                                           <![CDATA[
                                                           import mx.controls.Text;
                        import mx.validators.Validator;
                        import mx.events.ValidationResultEvent;
                        import mx.controls.Alert;
                        public var formIsValid:Boolean = false;
                        public var formIsEmpty:Boolean = true;
                                           public var selectedUser:UserObject;
                        private var focussedFormControl:DisplayObject;
                        private function validateForm(event:Event):void
                            focussedFormControl = event.target as DisplayObject;
                            formIsValid = true;
                            formIsEmpty = (txtNomeUtilizador.text == "" && txtUsername.text == ""
                                && txtPassword.text == "" && txtRepetirPassword.text == "");
            validate(nameValidator);
                            validate(userValidator);
                            validate(passValidator);
                            validate(rpassValidator);
                         private function validate(validator:Validator):Boolean
                             var validatorSource:DisplayObject = validator.source as DisplayObject;
                            var suppressEvents:Boolean = (validatorSource != focussedFormControl);
                            var event:ValidationResultEvent = validator.validate(null, suppressEvents);
            var currentControlIsValid:Boolean = (event.type == ValidationResultEvent.VALID);
                             formIsValid = formIsValid && currentControlIsValid;
                             return currentControlIsValid;
                        private function submitForm():void
        if(txtPassword.text!=txtRepetirPassword.text) Alert.show("As Paswords são diferentes!");
        else srv.send();
            </mx:Script>
            <mx:StringValidator
                    id="nameValidator"
                    source=""
                    property="text"
                    minLength="2"
                    requiredFieldError="Tem que preencher o Nome do utilizador."
            <mx:StringValidator
                    id="userValidator"
                    source=""
                    property="text"
                    minLength="2"
                    requiredFieldError="Tem que preencher o Username."
            <mx:StringValidator
                    id="passValidator"
                    source=""
                    property="text"
                    minLength="2"
                    requiredFieldError="Tem que preencher a Password."
            <mx:StringValidator
                    id="rpassValidator"
                    source=""
                    property="text"
                    minLength="2"
                    requiredFieldError="Tem que Repetir a Password."
            PHP FILE:
            $SERVIDOR = mysql_connect("localhost","webuser","Wsis2003");
            $BD = mysql_select_db("bdweb");
            if (!$SERVIDOR) die('Não foi possível conectar ao Servidor: ' . mysql_error());
            if (!$BD) die('Não foi possível aceder à  BD: ' . mysql_error());
            $nome = $_POST['nome'];
                  $username = $_POST['username'];
                  $password = $_POST['password'];
                  $tipo = $_POST['tipo'];
                  $hoje = date("d-m-Y \á\s H:i:s");
                  $sql = "SELECT MAX(id) as id FROM users";
                  $result = mysql_query($sql);
                  $array = mysql_fetch_array($result);
                  $id = $array["id"] + 1;
                  $dir = “DIR”.$id;
                  $sql = "INSERT INTO users(id,nome,user,pass,tipo,data,activo,pasta,ulogin)
                              VALUES(".$id.",'".$nome."','".$username."','".$password."','".$tipo."','".$hoje."','Sim', '".$dir."','".$hoje."')";
                  if($result)
                        if(!file_exists($dir)) mkdir($dir,0777,true);
                        echo("Utilizador introduzido com sucesso!");
                  }else echo("Não foi possível criar o Utilizador.");
            Regards,
            Vitor Correia
            • 3. Re: Update DataGrid!
              Do you get a successful result?  Does that result contain the updates?
              Alex Harui
              Flex SDK Developer
              Adobe Systems Inc.
              • 4. Re: Update DataGrid!
                Vitor Wsis Level 1
                The "result" value of the php file is ok! The data is inserted correctly in the MySQL DataBase!
                However i do not visualize the introduced data with a simple page refresh, or page "init()".
                I have to re-compile the Flex aplication to be able to see the newlly introduced data!
                NOTE: This data can be seen on the DataBase at all time.
                • 5. Re: Update DataGrid!
                  See if the DataGrid gets a collectionChange event when the data is updated.
                  Alex Harui
                  Flex SDK Developer
                  Adobe Systems Inc.
                  • 6. Re: Update DataGrid!
                    Vitor Wsis Level 1
                    I still don't have a deep knowledge on Flex language.
                    Where i can find that collectionChange event?
                    • 7. Re: Update DataGrid!
                      In the documentation.  Should also be there as CollectionEvent.  It will be dispatched from the dataProvider and the DataGrid should have a collectionChangeHandler method that gets called
                      Alex Harui
                      Flex SDK Developer
                      Adobe Systems Inc.
