3 Replies Latest reply on Jul 21, 2009 8:51 AM by BobFromTheYear5K
    HTTPService.send() not sending request
    BobFromTheYear5K Level 1
      Hello,
      I've got what is probably a newbie problem.
      I have an event handler for "creationComplete" in my MXML Application tag.
      In my event handler, I want to send a request to a back-end PHP page.
      private function onCreated():void
           // Build the HTTP Request to send to the backend PHP.
           // Retrieves the list of images for the current Property ID.
           var httpReq:HTTPService = new HTTPService();
           httpReq.method       = "POST";
           httpReq.request      = "id=" + Application.application.parameters.propertyID;
           httpReq.resultFormat = "e4x";
           httpReq.useProxy     = false;
           httpReq.url          = "http://localhost:8080/services/getPropertyFiles.php";
           httpReq.addEventListener( FaultEvent.FAULT, onReqFault );
           httpReq.addEventListener( ResultEvent.RESULT, onReqResult );
           Alert.show( "Sending Request" );
              // Send the request
           httpReq.send();
           Alert.show( "Request Sent" );
      If I hit the PHP page directly, it behaves as expected.  If I run my Flex app, I see the "Sending Request" Alert, but the "Request Sent" Alert is never displayed, neither of my HTTPService event handlers is ever called, Firebug shows no requests to my the back-end PHP & the Apache logs also don't show any activity for the PHP page.
      I'm obviously doing something wrong here, but I can't figure out what it is.
      Any ideas?
      --bob
        • 1. Re: HTTPService.send() not sending request
          Gregory Lafrance Level 6
          Try simplifying this to perhaps call google or something, just to confirm it is something with how you are configure the HTTPService.
          • 2. Re: HTTPService.send() not sending request
            Solved my own problem.
            Here's the source in case it helps anyone else:
                             // Build a parameters object
                             var params:Object = new Object();
                             params.id = Application.application.parameters.propertyID;
                             httpReq.request      = params;
                             // Add the listeners
                            // Send the request
                             httpReq.send();
            I replaced my parameter string with a parameter Object and voila!  Instant success.
            --bob
            • 3. Re: HTTPService.send() not sending request
              Hmmmm....
              That's odd.  The Source Insert didn't quite work that time....
