7 Replies Latest reply on Jul 27, 2009 1:55 PM by fenosc
    Customclass accessing children
    fenosc
      Hi there,
      I made a search looking for custom class problems but didn`t find anything about what I`m having trouble with. Witch I thought to be pretty weird. I think I may be doing something stupid.
      I have a customScrollBar_mc in my library which consists of 2 movieclips instanced as mcBar and mcBackGround.
      I exported customScrollBar_mc for actionscript with a custom class attached to it called CustomScrollBar and I UNchecked the export in frame 1 option (I left only the preloader things with that checked).
      Well, I made my CustomScrollBar class but the problem is. If I try something like this in its constructor
      mcBar.height = 10; or
      mcBackGround.width = 10;
      Flash tells me that those instances doesn`t exist.
      How can I make flash recognize them ?
      Here is some structure information:
      Project organization
      /Project
         /bin
         /src
           Main.as
           /sessions
             CustomScrollBar.as
             Session.as this class instances CustomScrollBar
      Export SWC is checked.
      Sourcepaths added are /src and /src/sessions
      Automatically declare stage instances is UNchecked.
      All my files have no PACKAGE especification (if I add "sessions" to the package name it tells me that it doesn`t especify the real location of the files. Don`t know why this happends.)
      Could anyone please help me with this ?
      Thanks in advance,
      Oscar
        • 1. Re: Customclass accessing children
          recheck export in frame 1 to test.  make sure both child movieclips exist in frame 1.
          • 2. Re: Customclass accessing children
            fenosc Level 1
            Hi kglad!
            Didn`t work.
            One thing though, you told be to be sure that they are on frame 1.
            Here is the thing, they are not. I instance my CustomScrollBar during my code in the Session.as and the errors telling me the mcBar and mcBackGround don`t exist happen in the CustomScrollBar constructor, where I change some of their values.
            Something like
            var scroll:CustomScrollBar = new CustomScrollBar();
            and inside the constructor is
            mcBar.height = 10;
            Any idea ?
            • 3. Re: Customclass accessing children
              fenosc Level 1
              upping the topic so it wont be forgotten
              sorry about this.
              What I could do to fix this is instance a CustomScrollBar from my library into my CustomScrollBar class, but that seems a little redundant to me. I don`t think that is the best way to solve this problem...
              Since the class already represents my object in the library, it should have access to its children.
              Thanks again
              • 4. Re: Customclass accessing children
                fenosc Level 1
                Hi there, the topic was on the 4th page so I decided to make some screenshots and explain better this so it would be easier to help me out.
                I don`t have a clue about it and I just crossed a point where I can`t go any further without this.
                I took a photo of my publish settings, library, movieclip properties andproject folder so you can understand what is happening.
                First of all, the problem is related to the topico_mc movieclip (translation: topic_mc)
                topico_mc is composed by:
                movieclip topico_quadrado_mc (translation: square_topic_mc) that is just a small square: mcSquare
                dynamic text: dynText
                I export it to actionscript with class name TopicosFlash and unchecked export in frame 1 (I tested with this checked too). I also tried browsing my symbol in the Source field just as shown in the screenshot.
                I make the TopicosFlash.as file, make it extends movie clip and add a simple code to the constructor: mcSquare.alpha = 1
                In the document class I simply add it: addchild(new TopicosFlash());
                The issue: mcSquare is a undefined property
                Screenshot:
                http://img24.imageshack.us/img24/6344/telasflash.jpg
                Trying to solve this I found some things that for me were strange:
                1) If I don`t make the TopicosFlash.as file, the movieclip is added with no problems.
                2) If I make the TopicosFlash.as file but let it empty flash throw an error: Cannot create property dynText on TopicosFlash.
                3) If I make the file, it gives the mcSquare undefined error.
                Sorry for the bad words but wtf is going on?
                I really am not being able to understand this and I can`t find any answers anywhere.
                Thanks in advance,
                Oscar
                • 5. Re: Customclass accessing children
                  Rothrock Level 5
                  You haven't shown your class file. But in the variable declaration do you have a line such as:
                  public var mcSquare:Movieclip;
                  If you don't how is the constructor to know that this class has such a thing?
                  • 6. Re: Customclass accessing children
                    fenosc Level 1
                    Hi there,
                    Thanks for the answer!
                    Well, I didn`t declare any mcSquare variable because since the whole movieclip was exported with a custom class, that custom class should have access to its children. But that is not happening in my case.
                    Well, I did try what you said, I declared a variable a variable mcQuadrado but it doesn`t work either.
                    If I don`t have a custom class, I can instance my topic_mc movieclip with no problems. I can also access its children with objectName.childrenInstanceName command. But with custom class I`m not able to.
                    Here is what I want to do.
                    In Flash IDE I want to have lots of topic_mc objects with different instance names and by code I`ll change their content and some of their behaviors.
                    This way I can position them all in flash IDE and change their content by coding. This makes my life much easier since I don`t have to make different buttons for different contents. I just nee to change the content by code and the rest will be automatic.
                    But this class problem is not alowing me to do that and I`m strangely thinking that this might not be possible? If that is right, I don`t have any ideas on how and why using custom classes.
                    Still needing help with this matter =(
                    Oscar
                    • 7. Re: Customclass accessing children
                      fenosc Level 1
                      Hi again Rothrock.
                      Problem solved! You were right!
                      But with your explanation alone I couldn`t do it. A guy in other forum told me that PUBLIC is a must. I was trying with private (I like making my classes closed, but I didn`t think it would be a problem until now).
                      I didn`t imagin either that I would need to add the instances as children again. By doing so I though i would be adding anothe instance of objects that are already there.. but hey... it is not what happened.
                      Now I`m able to continue.
                      Thanks alot.
                      Oscar
