19 Replies Latest reply on Feb 27, 2011 9:25 AM by Cheny Tech
    Audio track freeze
    Smact
      I am having a porblem when I add a clip to the time line, if I expand the audio track it freezes, I can not select, edit or move the audio, it acts as if it is locked byt it is not. If I minimize the audio track I can sleect it, and edit it. Any ideas on what is causing this to happen?
        • 1. Re: Audio track freeze
          Jim_Simon Level 8
          I'm not even sure I understand what is happening, let alone offer an explanation as to why.
          • 2. Re: Audio track freeze
            Smact Level 1
            Seems very strange, I have gone over the settings, started a new project, used different clips but it does the same thing. As soon as I expand the track it freezes, won't even allow me to right click and check the properties of the clip. Like my note said it asks like it's locked but it's not. The clips are MPG format. Another thing I noticed is when the clip is expanded if I put the cursor on the clip and left click the cursor turns into a plus sign and as I move it becomes a box that expands as I move along the clip, but won't select even if I hold down the ALT key.
            Thank You
            Scott MacTavish
            West TV Technical Director
            Western Financial Group Inc.
            1010 - 24 Street SE, High River, AB  T1V 2A7
            Ph: 403-652-2663 Ext. 253 Fax: 403-652-7037
            scott.mactavish@westernfinancialgroup.net
            www.westernfinancialgroup.net
            • 3. Re: Audio track freeze
              shooternz Level 6
              Try exporting the audio to a wav file before editing it.
              • 4. Re: Audio track freeze
                the_wine_snob Level 9
                With the Timeline "unexpanded," does everything work, as it should?
                I'm wondering if there might be something with your display driver not being able to handle the Waveform Display. The cursor's odd behavior leads in that same direction. What vid-card and driver version do you have?
                Also, with the Timeline unexpanded, Rt-click on the MPEG Audio Clip and try Render/Replace. That should convert it to a PCM/WAV and replace it on the Timeline.
                • 5. Re: Audio track freeze
                  Jim_Simon Level 8
                  That has caused issues many times before.  My advice is to just not use them.
                  • 6. Re: Audio track freeze
                    Smact Level 1
                    I just tried an AVI clip, and it does the same thing. Running out of ideas, wonder if there is a setting I don't know about?
                    Thank You
                    Scott MacTavish
                    • 7. Re: Audio track freeze
                      I am assuming that your AVI had PCM/WAV Audio. Is that correct?
                      Any luck on the vid-card drivers?
                      • 8. Re: Audio track freeze
                        PPro Troubleshooting http://premierepro.wikia.com/wiki/Troubleshooting
                        If still not fixed, return with DETAILS asked for in questions at end
                        • 9. Re: Audio track freeze
                          Smact Level 1
                          Here is what I get when I check the file properties. Wondering if the is there anything strange with the source audio and project audio format?
                          File Path: V:\Premiere\West TV Intro\Devin Lindsay2_40_42 PM.mpg
                          Type: MPEG Movie
                          File Size: 12.1 MB
                          Image Size: 720 x 480
                          Pixel Depth: 32
                          Frame Rate: 29.97
                          Source Audio Format: 48000 Hz - compressed - Stereo
                          Project Audio Format: 48000 Hz - 32 bit floating point - Stereo
                          Total Duration: 00;00;15;26
                          Average Data Rate: 779 KB / second
                          Pixel Aspect Ratio: 0.9091
                          Going to have our IT tech that build the computer check the vid-card drivers
                          Thank You
                          Scott MacTavish
                          • 10. Re: Audio track freeze
                            With PCM/WAV Audio stream, this should say "uncompressed." I'd run the file though G-Spot to see what it says about the Audio, and if there is a CODEC listed.
                            • 11. Re: Audio track freeze
                              Jim_Simon Level 8
                              That alone could still cause these issues.  Try a DV clip captured by you over Firewire using Premiere from a tape based MiniDV camera.
                              • 12. Re: Audio track freeze
                                Smact Level 1
                                I tried a clip right from a tape, still same problem. Starting to think it maybe something to do with Vista, we loaded Premiere onto a PC with XP and it works fine., matched all the settings on the 2 PC's used the same clips and the XP version works, Vista it freezes the audio as soon as you expand the audio track.
                                Thank You
                                Scott MacTavish
                                • 13. Re: Audio track freeze
                                  Smact Level 1
                                  I have spent 2 days talking to 4 different Adobe  help desk techs, have 2 more case numbers #181081547, and #202307698. I was asked to un install Premiere CS4, run a clean script, did so, re in stall then check if the problem was fixed, if not it would be escalated up the help desk, I ended up at a jr tech again and was told he could not help me. Not sure if anyone will see this note but have to comment on how poor the service has been. Still have not had any replies from Adobe about the case numbers other than they say they have been closed, not solved!!!!!
                                  • 14. Re: Audio track freeze
                                    That does not bode well for Adobe TS.
                                    There seems to be a lot of this going around. Many have reported the same situation. With some, upon questioning Adobe, were told that they had been sent e-mails to furnish more and specific info. In those cases the posters claim to have never gotten the e-mails. Still, enough instances to make one wonder.
                                    • 15. Re: Audio track freeze
                                      markharrigan
                                      Scott,
                                           It stands to reason that if it is working fine in XP but not Vista...that might be the problem.  Download any updates that Microsoft might have for Vista.  (I am using Vista 64 bit and it works fine.)  Also, have you downloaded all the updated for the CS4 suite...there were a lot of them, as I recall.
                                      mark
                                      • 16. Re: Audio track freeze
                                        Jim_Simon Level 8
                                        From which model camera?
                                        • 17. Re: Audio track freeze
                                          mike velte Level 1
                                          At the left end of the track is a "Show Keyframes" button.  Make sure it is set to "Show Clip Keyframes", not TRACK.
                                          • 18. Re: Audio track freeze
                                            Smact Level 1
                                            Well I can't believe it, but your suggestion Mike help fix the problem. I checked the show key frame button, it was set to " Show Track Volume" , selected "Hide Key Frames" now I can select, edit , move , delete the audio.  Thanks everyone for your help, I feel like a fool, but had tried every button, setting but that one, guess I missed it.
                                            • 19. Re: Audio track freeze
                                              Cheny Tech
                                              Thank you!  Thank you! Thank you!
                                              I had the exact same problem and I just spent a day trying to figure this out on my own...then I found your post with the solution.
                                              I guess I should have checked here first.
