• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
uninstall vs deactivate
Guest
Jul 21, 2009 Jul 21, 2009
I have to move my Frame 9 installation to a new drive.
I have uninstalled Frame 9 from the existing drive, but a colleague says I needed to deactivate it.
Did the uninstall perform a deactivation automatically?  If not, how do I regain the installation rights from the previous instance?
Views
7.3K
Translate
Translate
Report
Report
Community guidelines
community guidelines
LEGEND ,
AFAIK, if the re-installation is on the same machine, then you don't have to deactivate. There's a set of activation FAQs at: http://www.adobe.com/products/activation/
Votes
Translate
Translate
Report
Report
Guest
Thanks. I don't know what the IT guys have planned -- same processor, new drive, or whole new machine. All I know is this one's acting up and they want to rebuild it.
I'll read the FAQ. Thanks for the pointer!
Votes
Translate
Translate
Report
Report
LEGEND ,
I have to disagree here. If you reformat the drive, you don't need to reactivate, but I believe a new drive will require activation. I'd rather be safe and de-activate even if it means re-installing the software first. If its not possible and you have used your activations, Adobe will grant you an additional activation. So I wouldn't sweat it, but if I can avoid the hassle, I do.
Votes
Translate
Translate
Report
Report
LEGEND ,
If the machine is being rebuilt, rather than just a new drive being added, then I would go with Mike's recommendation to deactivate. The Adobe Licensing software is finicky & ornery, hiding stuff all over your drive. If you replace the drive, then this prior info is lost and you could be up the creek without a paddle. I just went through an exercise in frustration trying to get all components of the TechCommSUite running properly after a disk glitch forced me to LicenseRepair and re-install, since I couldn't deactivate prior to having the disk hiccup. The only saving grace was a deactivation followed by an uninstall, running Adobe's clean scripts and a re-install to get things working properly.
Votes
Translate
Translate
Report
Report
Guest
Jul 22, 2009 Jul 22, 2009
Thanks, but it's moot; I've already uninstalled. To deactivate it I would have to install it again. But if I attempt an install, I am asked for the license key, so it's not clear whether my prior activation is still in effect.
Votes
Translate
Translate
Report
Report
Enthusiast ,
I've never had a problem with Adobe tech support when something like this has happened -- installation support is free, and they're quite familiar with this scenario. So best case is the software will go on and activate without a hitch. Worst case is the activation will be screwed, which means you have a 30-day window during which the software works to give you a window to call Adobe tech support and get it resolved. Which usually isn't a big deal -- just keying in a new key.
Art
Votes
Translate
Translate
Report
Report
Guest
LATEST
Thanks, I've filed a Customer service case and am waiting to hear back. If they're familiar with this scenario, maybe they should do something about it!
Votes
Translate
Translate
Report
Report
