6 Replies Latest reply: Mar 27, 2014 5:48 PM by RodWard RSS
    Quiz Scoring with infinite attempts
    Rich146 Community Member
      Goal: When the user selects the wrong answer I want them to be able to continue to select answers until they select the correct answer BUT are graded "incorrect" for the score on that slide for picking the wrong answer first. I thought there was a way to do this but cannot find it. Suggestions.....
        • 1. Re: Quiz Scoring with infinite attempts
          sarahw222222 Community Member
          Does anyone know the answer to this? I'm running into the same issue.
          • 2. Re: Quiz Scoring with infinite attempts
            RodWard CommunityMVP
            You cannot do this with standard quiz questions because if the learner EVER selects a correct answer for that question then Captivate will of course mark it as being correct.
            Instructionally speaking, asking a user to eventually get a question correct, and then marking their question as incorrect, is somewhat counter-intuitive don't you think?  If they were only really allowed one attempt to get the question correct, why have them jumping through hoops to eventually get it right and then be told it was a futile effort anyway because they were failed on the first attempt?  Adult learners don't enjoy futility.  Reward them for sticking with the task until success is achieved.  It's a better strategy in my view.
            You could potentially set up a custom slide with interactive objects to achieve this result, but it will not be using a quiz question slide, and it would not be counted as part of the Quiz Review (if you were using that feature).
            • 3. Re: Quiz Scoring with infinite attempts
              Sorry, i wasn't very clear on why I'm looking to do this. I'm actually looking to do it in an assessment rather than a quiz. What I'd like to happen is this:
              -learner is given instructions and they need to click on an area of the screen.
              -the first time they click on the wrong area of the screen, a caption appears giving them a hint (i'm not using the built-in hints in captivate, i've built something else that accomplishes this)
              -the second time they click on the wrong area, a point is deducted from their score, and a caption appears telling them where they should've clicked. right now, i have this set up in captivate with a failure caption. i want the user to be forced to click the right area before they can progress in the assessment (hence the infinite attempts), but i want that second attempt to be scored.
              thoughts on how to do this?? any help is greatly appreciated!
              • 4. Re: Quiz Scoring with infinite attempts
                Lilybiri CommunityMVP
                Do you need to report the score to a LMS?
                http://blog.lilybiri.com/link-score-to-attempts-in-custom-questions    just to see how much work this will need. I'll leave you to Rod for the rest of the thread.
                • 5. Re: Quiz Scoring with infinite attempts
                  Yes, we need to report it to an LMS. Does that make it impossible?
                  Thanks for the link - I will take a look right now!
                  • 6. Re: Quiz Scoring with infinite attempts
                    If you're using scorable interactive objects (e.g. click boxes or buttons) to register the clicks from the user then you can certainly set these to report to the quiz, which will then be reported to the LMS.
                    However, any successful action for these interactive objects will then contribute to the score.
                    So if the user clicks unsuccessfully on the first attempt, they will NOT get any points added to the score.  But clicking successfully on the target area for their second attempt WOULD get them points added to the quiz.
                    On completion of their quiz attempt, if they continue past the Quiz Results slide, their score will be sent to the LMS.
