0 Replies Latest reply on Jul 21, 2009 3:19 PM by Ansury
    Does FB 4 warn you when a class in your project is NOT compiled into your swf?
    Ansury Level 3
      If you don't have any explicit references to a class, it won't be included in the swf, which may help reduce the size since it's not being used anyway (although still I'd like a warning so I can maintain a cleaner project).
      Well, this is a problem if you're using remoting because you'll end up with "Objects" instead of retaining the strong typing of the object sent via Java/etc.  It's annoying when you're finishing your most initial stages of integration; you're just checking to see if everything works, and you forget to reference the class somewhere...
      Would be nice if we had a warning in Flash Builder when a class in our project is ignored. If FB4 doesn't have this, it should.
