0 Replies Latest reply on Jul 21, 2009 4:19 PM by Chet Haase
    [svn:fx-trunk] 8723: Fixed 2 areas of effects bugs ( playheadTime and transform effects shared instances).
    Chet Haase Level 3
      Revision: 8723
      Author:   chaase@adobe.com
      Date:     2009-07-21 16:19:39 -0700 (Tue, 21 Jul 2009)
      Log Message:
      Fixed 2 areas of effects bugs (playheadTime and transform effects shared instances). Also fixed bug in GraphicElement.localToGlobal(). Fixes remaining transform effects bugs prior to feature signoff.
      QE Notes: None
      Doc Notes: None
      Bugs: SDK-22315, sdk-22304, sdk-22302, sdk-21931, sdk-21068, sdk-20179, sdk-21069
      Reviewer: Hans, Jason (GraphicElement), Glenn (SharedObjectDepot)
      API Change: None
      Is noteworthy for integration: No
      tests: checkintests mustella spark/effects,mx/effects (run locally and in cyclone by Matt)
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-22315
          http://bugs.adobe.com/jira/browse/sdk-22304
          http://bugs.adobe.com/jira/browse/sdk-22302
          http://bugs.adobe.com/jira/browse/sdk-21931
          http://bugs.adobe.com/jira/browse/sdk-21068
          http://bugs.adobe.com/jira/browse/sdk-20179
          http://bugs.adobe.com/jira/browse/sdk-21069
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/framework/src/mx/effects/Effect.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/effects/EffectInstance.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/effects/effectClasses/CompositeEffect Instance.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/effects/effectClasses/ParallelInstanc e.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/effects/AnimateTransform.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/effects/Fade.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/effects/animation/Animation.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/effects/interpolation/HSBInterpolator. as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/effects/interpolation/NumberInterpolat or.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/effects/interpolation/RGBInterpolator. as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/effects/supportClasses/AnimateInstance .as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/effects/supportClasses/AnimateTransfor mInstance.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/primitives/supportClasses/GraphicEleme nt.as
      Added Paths:
          flex/sdk/trunk/frameworks/projects/spark/src/spark/effects/SharedObjectDepot.as
