6 Replies Latest reply on Jul 22, 2009 2:36 PM by Laubender
    JS CS4: strokeDashAndGap question
    John Kallios Level 2
      var myOutsideGuide_Left = app.activeDocument.pages[0].graphicLines.add (app.activeDocument.layers.item ("Die"));
      myOutsideGuide_Left.geometricBounds = ["0 in", "3 in", "10 in", "3 in"];
      myOutsideGuide_Left.strokeDashAndGap = ["3 p", "3 p","3 p","3 p"];
      myOutsideGuide_Left.strokeColor = app.activeDocument.colors.item("Black");
      "myOutsideGuide_Left.strokeDashAndGap = ["3 p", "3 p","3 p","3 p"];" this line errors out and I'm stumped at what I'm missing.
      Insight is greatly appreciated.
      Thank you,
      John
        • 1. Re: JS CS4: strokeDashAndGap question
          myOutsideGuide_Left.strokeType = "Dashed";
          It seems you can only set the dash properties if the line is tagged as 'being dashed' in the first place!
          • 2. Re: JS CS4: strokeDashAndGap question
            Thank you very much for taking the time to help with novice questions. It is greatly appreciated.
            To recap:
            (the following is for other uninitiate like me)
            Not using "myOutsideGuide_Left.strokeDashAndGap = ["3 p", "3 p","3 p","3 p"];" will use the default of whatever dash and gap is recorded in the stroke palette "Dashed" setting.
            Thanks again for the help!
            • 3. Re: JS CS4: strokeDashAndGap question
              ... whatever dash and gap is recorded in the stroke palette "Dashed" setting ..
              I was wondering about that. This will still fail on other language versions of InDesign (because "Dashed" will be "Gestrichelt" or something like that), but I can only find one way of setting a line to a dashed style without knowing the name: loop over all stroke styles and use the first one that has a property "dashArray". Seems a bit ... troublesome?
              • 4. Re: JS CS4: strokeDashAndGap question
                Hi, Jongware!
                $ID/
                does it:
                myOutsideGuide_Left.strokeType = "$ID/Dashed";
                I tested that line on a German version of InDesign CS4 6.0.3 and InDesign CS3 5.0.4 on Mac OS X 10.5.7.
                Without "$ID/" there was an error.
                Greetings,
                Uwe
                • 5. Re: JS CS4: strokeDashAndGap question
                  Hi Uwe,
                  Thanks for posting that! It seems this invokes the built-in auto-translator, and having an English version only, no way I could have found that out, or even could've checked if it worked ...
                  Theun (aka [Jongware])
                  • 6. Re: JS CS4: strokeDashAndGap question
                    Hi, Theun!
                    Search for "$ID/" or "Localization" in the pdf or html-documentation of the InDesign CS4 SDK:
                    Feature development with Scripting.pdf
                    p12 "Localization"
                    or to clarify the issue:
                    ar42s03s05.html
                    see also:
                    idml-specification.pdf
                    p224 "IDML Example 62. Default StrokeStyles"
                    Greetings,
                    Uwe
