11 Replies Latest reply on Jul 29, 2009 2:43 AM by zakabalt
    Pass values between components
    zakabalt Level 1
      Hello, this is my first questions in this forum and I hope that somebody can help me.
      I'm using components in my application and I want to get one value that I create in one component in another component. I know that exist more than i can do in differents forms, but I want to choose the best. Here the code to explain better my questions.
      Component1:
      <mx:Canvas xmlns:mx="http://www.adobe.com/2006/mxml" width="164" height="36">
         <mx:Script>
            <![CDATA[
             //Metemos el id de la cuenta que queramos cargar
             public function queCuenta():Number {
                  var idAccount:Number = Number(accountnumber.text);
                  return idAccount;
         </mx:Script>
         <mx:TextInput id="accountnumber" x="74" y="8" width="36"/>
         <mx:Label x="25" y="10" text="Cuenta" width="62"/>
         <mx:Button x="118" y="8" label="OK" width="42" click="queCuenta()"/>
      </mx:Canvas>
      I want to use idAccount in another component. I want to print this number in another component label. Which is the best code to do that?
      Thanks and sorry, but my english is not very good.
        • 1. Re: Pass values between components
          Madhav Subedi Level 4
          use setter and getter methods:
             <mx:Script>
                <![CDATA[
          private var _idAccount:Number;
          public function set idAccount(value:Number):void
          this._idAccount = value;
          public function get idAccount():Number
          return this._idAccount;
                      //var idAccount:Number = Number(accountnumber.text);
                      //return idAccount;
          this._idAccount = Number(accountnumber.text);
             </mx:Script>
          </mx:Canvas>
          However, if you want to get the value everytime the value is changed, you need to use custom events.
          • 2. Re: Pass values between components
            zakabalt Level 1
            I want to use this value when change also. I have one function in another component and when the idAccount is one the function get one String and when the numer is 2 another, when is 3 other...
            Which is the code of the second component? I don't know how can I get the number.
            Component2:
            <canvas...>
            <Script...>
                 private function treeLoaded():void
                       srv.getCarpeta(idAccount);
                      //this the code when I had the 2 components in 1. But now I have 2 components and I don't know what put it here, or why.
            </Script>
            </canvas>
            • 3. Re: Pass values between components
              You need to fire an event when value is changed.
              this is done using dispatchEvent(); method.
              MyComponent.mxml
                 <mx:Script>
                    <![CDATA[
                          //return idAccount;
              dispatchEvent(new Event('valueChanged'));
                 </mx:Script>
              </mx:Canvas>
              application where this component is used.
              <local:MyComponent id="mc" valueChanged="Alert.show(mc.idAccount.toString())">
              • 4. Re: Pass values between components
                zakabalt Level 1
                Thanks for your help. I understand what i have to do.
                • 5. Re: Pass values between components
                  Gregory Lafrance Level 6
                  You are best off using custom events because that will lead to a more loosely coupled application and is a best practice.
                  Here is my Flex 3 Cookbook post on using custom events in a simple MVC application:
                  http://www.adobe.com/cfusion/communityengine/index.cfm?event=showdetails&productId=2&postI d=11246
                  If this post answers your question or helps, please mark it as such.
                  • 6. Re: Pass values between components
                    zakabalt Level 1
                    Which is the library of valueChanged? "Cannot resolve attribute 'valueChanged' for component type comp.MyComponent"
                    And if I want use the same _idAccount in other component and not in the application, how can I do it? Here you have the code of MyComponent2 , but I don't know how I have to initialize or registry _idAccount in this component. I have tested in different logical forms(logical for me), but I haven't get. I hope that someone can complete this code to work with the code of MyComponent.
                    MyComponent2:
                    <mx:Canvas xmlns:mx="http://www.adobe.com/2006/mxml" width="100" height="20">
                    <mx:Script>
                            <![CDATA[
                            public function estaCuenta():void {
                                label.text = _idAccount;
                    </mx:Script>
                        <mx:Label id="label" width="100%" height="100%"/>
                    </mx:Canvas>
                    Thanks!
                    • 7. Re: Pass values between components
                      zakabalt Level 1
                      Someone can help with these two problems?
                      • 8. Re: Pass values between components
                        you need to put a meta tag in the component, to show which events is the component going to dispatch.
                        [Event(name="eventName", type="package.eventType")]
                        in your case:
                        [Event(name="valueChanged", type="flex.events.Event")]
                        • 9. Re: Pass values between components
                          zakabalt Level 1
                          I never use an expression like this. I don't know where I have to put. I put it in the <Script>.... but I have one error 'metadata requires an associated deffiniton'. Probably I'm putting in the wrong place I don't know.
                          An the other question? Where or why I have to import or declarate the components?
                          • 10. Re: Pass values between components
                            it is placed before the script tag, i mean inside the main tag.
                            like:
                               <mx:Script>
                                  <![CDATA[
                            seems that you need to study a bit more about custom events:
                            http://livedocs.adobe.com/flex/3/html/help.html?content=createevents_1.html
                            • 11. Re: Pass values between components
                              zakabalt Level 1
                              Thanks. With your link I get it. In your code you have an small error. It's flash.events.Event, not flex.events.Event, but with the link I have get.
                              And I have had put <Metadata>[Event(name.....]</Metadata>
                              Thanks!
