0 Replies Latest reply on Jul 22, 2009 8:18 AM by Paul Reilly
    [svn:fx-trunk] 8734: * Attempt to fix performance testsuite OutOfMemory error and fix
    Paul Reilly Level 1
      Revision: 8734
      Author:   preilly@adobe.com
      Date:     2009-07-22 08:18:09 -0700 (Wed, 22 Jul 2009)
      Log Message:
      • Attempt to fix performance testsuite OutOfMemory error and fix
        CollapseWhiteSpace regression.
      tests Passed: checkintests, performance testsuite
      Needs QA: YES
      Needs DOC: NO
      Bug fixes: SDK-22346
      API Change: NO
      Reviewer: Peter D.
      Cycloner: Gaurav (He found the performance testsuite still to be
                running out of memory, but it's working for me.  I'll turn
                off metadata inheritance and reopen SDK-14251 if it still
                runs out of memory.)
      Is noteworthy for integration: NO
      Code-level description of changes:
        abc/AbcCompiler.java
        as3/As3Compiler.java
          Removed duplicated AttrTypeTable constant.
          Reverted change to analyze4() made in revision 8682.
        as3/reflect/Assignable.java
        as3/reflect/TypeTable.java
          Added setTypeTable().
        as3/reflect/As3Class.java
          Modified setTypeTable() to apply the new TypeTable to each
          variable, method, getter, and setter.
        SymbolTable.java
          Added TYPE_TABLE constant and clean().
        mxml/reflect/TypeTable.java
          Changed (mdList != null) checks into (!mdList.isEmpty()).
          Updated getMetaDataList() javadoc to document that null is never
          returned and an empty list can be returned.
        as3/binding/TypeAnalyzer.java
          Modified buildClassInfo() to reset the TypeTable's SymbolTable if
          it's null before looking up SkinPart metadata.
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-22346
          http://bugs.adobe.com/jira/browse/SDK-14251
      Modified Paths:
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/SymbolTable.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/abc/AbcCompiler.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/As3Compiler.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/binding/TypeAnalyzer.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/reflect/As3Class.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/reflect/Assignable.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/reflect/TypeTable.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/reflect/TypeTable.java
