17 Replies Latest reply on Jul 30, 2009 9:23 AM by Mark Lindberg
    Dynamic data connection
    drcaesar
      I was wondering if there is a way to setup data connection to call web services dynamically.
      There are 3 environments (Dev, Test, and Production) and each environment has designated web services server.
      For example, http://devserver is for dev web services, http://testserver is for web services for test environment.
      What I'm trying to achieve is that I want to be able to create a pdf in dev environment and then promote it to the test server where the pdf has to call http://testserver instead of http://devserver without having to modify data connection everytime I promote a pdf.
      Thanks in advance.
        • 1. Re: Dynamic data connection
          pguerett Level 6
          You can dynamically set the submit address for web services but you woudl need to pass that info into the form in some way. How do you know which environment you are supposed to submit to?
          Paul
          • 2. Re: Dynamic data connection
            drcaesar Level 1
            Hi Paul,
            Thanks for your reply.
            I know which environment the application is running because the web application which retrieves the pdf through LiveCycle web service knows where it is running based on configuration.
            So if I can set the web services address dynamically, that will be great because I can pass the web services address.
            Thanks.
            • 3. Re: Dynamic data connection
              pguerett Level 6
              The command you want is:
              xfa.connectionSet.DataConnection.soapAddress.value
              where DataConnection is the name of the connection that you gave it when you set it up.
              Paul
              • 4. Re: Dynamic data connection
                drcaesar Level 1
                Paul,
                Thanks for your answer.
                Would you please elaborate where and how can I use xfa.connectionSet.[DataConnectionName].soapAddress.value?
                A way I was thinking was that setting the soap address in the LiveCycle process at runtime. I'd be better if there's a better way.
                I was able to set submit url dynamically using an input paramter (type of URLSpec) passed by my web application. So I was looking for a similar way to do it.
                Thanks a lot,
                Jake
                • 5. Re: Dynamic data connection
                  pguerett Level 6
                  You woudl have to get the address into a field on the form. You could set it in a xml data file and merge that file onto the template at render time. Then use the Form Ready event to get the value from the field at set the value ...using that command.
                  Paul
                  • 6. Re: Dynamic data connection
                    drcaesar Level 1
                    I was able to set the environment's soap address in a text field in the form - using XML Schema binding and process variable set by parameter.
                    And tried to assign the value to the web service data connection in the ready:form event.
                    xfa.connectionSet.WS.soapAddress.value = soapAddr.rawValue;
                    But it xfa.connectionSet.WS.soapAddress.value wouldn't change.
                    Anything missing here?
                    Jake
                    • 7. Re: Dynamic data connection
                      pguerett Level 6
                      What is the target version of your form (look in the form properties)?
                      Paul
                      • 8. Re: Dynamic data connection
                        drcaesar Level 1
                        I tried all possible target versions in the list - from 6.0.2 to 9.0.
                        None of them works.
                        xfa.connectionSet.MyDataConnection.soapAddress.value never changes and calls the old address.
                        Jake
                        • 9. Re: Dynamic data connection
                          pguerett Level 6
                          I just tried it here and it worked fine. I set my target to 7.0.5 and set the SoapAddress parameter. Make sure you do not include the ?wsdl in the call. I have included my test form .....it will not work for you as you do not have access to my servers but you can at least see what I did.
                          Paul
                          • 10. Re: Dynamic data connection
                            drcaesar Level 1
                            Thanks for your example.
                            That's exactly what I did in my XDP wondering why this simple script wouldn't work.
                            And your example doesn't work either. The two message boxes shows the same address which is the first one.
                            So, it seems that there must be something else that should make this thing work.
                            To test your pdf, I created a simple process with only two activities - Read Resource Content to read the file and Apply Usage Rights to apply reader extention.
                            Any ideas?
                            Jake
                            • 11. Re: Dynamic data connection
                              pguerett Level 6
                              I was playing with the target version before I sent it ...make sure it is set to version 7.0.5
                              That works on my machine
                              Paul
                              • 12. Re: Dynamic data connection
                                drcaesar Level 1
                                Yeah, the target version is set to 7.0.5.
                                Unfortunately, I tried all possible versions but none of them works...
                                It is so frustrating this simple script doesn't work.
                                • 13. Re: Dynamic data connection
                                  pguerett Level 6
                                  The issue has to do with some security that Acrobat added in version 8 that will not allwo you to modifythe connectionSet after the form has been rendered. I thought of a different way (based on an article that Stefan Cameron wrote) and it worked - for all versions. II clone the connectioSet nodes and adjust them instead. Have a look at this example and try the technique on your form.
                                  Paul
                                  • 14. Re: Dynamic data connection
                                    drcaesar Level 1
                                    Paul,
                                    I appreciate your help on this.
                                    It works now.
                                    Thanks again.
                                    Jake
                                    • 15. Re: Dynamic data connection
                                      Mark Lindberg Level 2
                                      Hi Paul:
                                      I've been trying to duplicate your process, and I am still having a problem.
                                      I have a web service that supports searching.
                                      It includes a query field to pass a string to the web service to search for, and a result field that is populated with the result.
                                      I have 2 versions of the service running to simulate Test and Production web services.
                                      I have linked the form to the Test version of the web service in Designer.
                                      I am trying to dynamically shift to the Production version at run time.
                                      I am cloning the data connection, populating the query field, and execting the connection.
                                      I am getting an operation failed message: Error attempting to read from file.
                                      I suspect that the query field's binding is not associated with the Production web service.
                                      The server that hosts the services does not register a hit.
                                      Any thougthts would be appreciated.
                                      Mark
                                      • 16. Re: Dynamic data connection
                                        pguerett Level 6
                                        Are you setting the soapconnection or the wsdl connection? If you post your form I will have a look.
                                        paul
                                        • 17. Re: Dynamic data connection
                                          Hi Paul:
                                          I solved the problem. It was not with your solution, but my service implementation.
                                          The service I was redirecting to had different security settings than the original.
                                          Once security was consistant, the technique worked fine.
                                          Thanks for the information, and offer of assistance.
                                          Mark
